FC rear alignment question
Old Aug 11, 2003 | 07:57 AM
hIGGI's Avatar
Okay
i have got this problem, even after swapping out few rear subframes/arms and so, i still can`t dial in zero TOE in rear. I managed to get camber on both sides right without getting mazdatrix links which allows you to set rear camber for each wheel, but best i was able to dial is 1/16" TOE in rear.
Would be right solution to make adjustable rear lateral link (longest link on rear suspension) ?
If yes, then its probably easiest thing i could do to get it straight - and having another thing which i could adjust independently for each side.....
thanks for any input
Old Aug 14, 2003 | 09:15 PM
bkapold@aol.com's Avatar
I feel your pain...I just had mine dialed in better from a pro and the best i could get it was 1 3/4 NEG camber....I had some toe as well...
Old Aug 20, 2003 | 12:56 PM
hIGGI's Avatar
i don`t feel pain, i am just asking and hoping for answer....
Old Aug 20, 2003 | 08:00 PM
and I gave you an answer.....
Old Aug 21, 2003 | 01:19 AM
hIGGI's Avatar
nope, u didn`t
only question in my post was this :
"Would be right solution to make adjustable rear lateral link (longest link on rear suspension) ?"
rx7jocke
Aug 15, 2015 03:36 PM
Marty RE
Aug 13, 2015 11:19 AM
