my front left side of car is lower
Old Aug 10, 2003 | 06:58 PM
Red face my front left side of car is lower
oky i have an 84 gs with 93k and the front driver side sits like 21 inch lower than the other side. I know that the ball joint seals are busted could this be my prop? Maybe the shocks or springs? also my driver rear end sits low to but the bar that connects it to the car is bent. Sould this effect the front ride hight?
Old Aug 10, 2003 | 09:50 PM
Pedestrian X's Avatar
SpAz!
loose some weight.
Old Aug 10, 2003 | 09:55 PM
Mr BiG G's Avatar
I'll Apex YOUR Seal
it should be your shocks...must be busted....wat kinda shocks and springs to u have on it?
Old Aug 10, 2003 | 11:43 PM
9bobo9's Avatar
i am using the stock shocks and they seem very stiff so it may be them buy i dont think so. It did this only after i jacked up the car using the a arm on that side
Old Aug 11, 2003 | 04:10 AM
You bent up your ****, by jacking it up in the wrong place.
Old Aug 11, 2003 | 10:11 AM
esoto66's Avatar
Originally posted by Pedestrian X
loose some weight.
Old Aug 11, 2003 | 10:34 AM
Mr BiG G's Avatar
I'll Apex YOUR Seal
oh man u jacked it on the wrong ****...ur s'posed to jack it on the side of the car or find some other spot prolly from a service manual
Old Aug 11, 2003 | 10:42 AM
Wankler20B's Avatar
Since when did shocks have anything to do with ride height?
Replace the springs.
Old Aug 11, 2003 | 11:07 AM
When one lifts a uni-body car, one must be carefull. Me, i never jack up a car from the rearend, or from the crossmember, but rather i use the frame rails that run along from the firewall to right before the rear wheels.
The owners manual will shed some light on this subject.
Read it !
Old Aug 11, 2003 | 11:41 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
There ARE gas shocks available for these cars which will definitely affect ride height, you know.
...but not 21 inches
Old Aug 11, 2003 | 01:00 PM
21 inch's ,,,Lol !
Old Aug 11, 2003 | 01:16 PM
Keaponlaffen's Avatar
I don't think my 'Yota even has 21" of ground clearance to sag....
Old Aug 11, 2003 | 02:00 PM
web777's Avatar
Read it !
What's wrong with jacking it from the rearend? That's what's holding the rear up anyways.
Old Aug 11, 2003 | 03:26 PM
SpAz!
id guess the rear suspension.
Old Aug 11, 2003 | 03:52 PM
I guess one could,, But me. I prefer to lift one corner at a time. Maybe more work for me, but i know exactley
where each stand is and where it's placed for safety.
Old Aug 11, 2003 | 03:55 PM
9bobo9's Avatar
to put a car that dont runt on thoses wheel stands you have to jack up the wheels not the suspension to slide it under the tire
Old Aug 22, 2003 | 12:29 PM
onepointone's Avatar
i say what i want
i always jack my car from the rear end, or the front cross member. thast whats holding the car up when its sitting on the ground anyway, how would it be bad for it?
Old Aug 22, 2003 | 12:34 PM
Metallic_rock's Avatar
Ride 'n Style
ditto
Old Aug 22, 2003 | 02:22 PM
'85 GSL 302's Avatar
I jack under the rear pumpkin. You DON'T jack under the lower control arm. That's how it get's bent among other ways. THat's what they're saying.
