Damn fuses... Need help lol
Old Aug 10, 2003 | 10:31 AM
The_Dude's Avatar
TT 1st gen ? We'll see !
Hey evrybody. I got this tinny little problem that drives the heck out of me and I was wondering if anybody can help me with it.
Within the first 5-10 minutes of me starting the car, If I give it too much gas, I blow the 20A engine fuse, which actually has the gas pump hooked up to it. Now all of you know a rex (or any car :P) Doesn't go to far without a gas pump ! If you guys need anymore details to help me solve it, PLEASE ASK ! ... I have spent 15-20$ in fuses within 2 months, that's 120$ a year FOR FUSES ! :P
Thanks alot guys ( and girls ) ,
Eric.
Old Aug 10, 2003 | 11:22 AM
rxtasy3's Avatar
U need to get a wiring diagram and find out what else is on that circuit. Will it run at idle for a long period of time and only blowing fuses on acceleration? Assuming ur car is a later model, u may have a TPS or something that is shorting out at a certain position. Just my guess.
Old Aug 10, 2003 | 02:21 PM
The_Dude's Avatar
Mine is an 84 GSL. I tried figuring it out, put it will only do it if I give it a big sudden push on the peddle in the 1st 5-10 min. I can`t floor it for the first couple of minutes , then it`s ok. I have even rewired my gas pump with a new wire all the way under the steering column but I still get the same problem.
:S:S
Thx alot guys !
Old Aug 10, 2003 | 03:54 PM
rxtasy3's Avatar
I still say find out what all is on that circuit. There may be a wire somewhere around the engine that is grounding when the engine torques up.
Old Aug 10, 2003 | 04:02 PM
The_Dude's Avatar
Very good plan .. I`ve got the complete wiring diagram on PDF lol ... I`ll try to fin it in there .. If any of you have seen this problem before, PLEASE TELL ME NE THING lol... What I find bizzare is that it only does it within the first 5-10 minutes lol .. NE ways thx !
Old Aug 10, 2003 | 07:28 PM
vipernicus42's Avatar
Rotoholic Moderookie
Eric,
Next time you're over I'll take out the Heynes and we can check that circuit.. Just remind me...
But also, does anyone have any idea of what, (other than a grounding problem) would cause something like that? Could one of the electrical parts on that circuit be going bad itself?
Jon
Old Aug 11, 2003 | 01:19 PM
The_Dude's Avatar
If we can't find it, I'll just buy that 100$ Rex and change the whole f*cking wiring that's connected to the pump :P alot less trouble I find
Old Aug 11, 2003 | 01:54 PM
anthrax's Avatar
Heck Yes!
By the sound of the problem the fuel pump is only a syptom of the actual problem. I have to agree with rxtasy3. There is some thing other then the fuel pump that is causing the fuse to blow. Find out what else is on that circet and go from there. If the pump was bad it would draw high amps all the time not just in the time you have discribed.
Good luck
anthrax
Old Aug 11, 2003 | 01:57 PM
The_Dude's Avatar
thanx for the tip! ... I figured it was a short .. can't be somthing big so I'll probably have to look for a while lol ... Oh well, me and Vieper will be spening all day tomorow working on our rexs' so it's all good ! .
P.s. We gotta get your car iddling FAST !:P
Old Aug 11, 2003 | 02:01 PM
Dom's Avatar
Dom
callin' tokyo
That 20 A fuse is also for:
-kickdown
-charging system
-emmission system
Old Aug 20, 2003 | 08:57 PM
The_Dude's Avatar
GOT IT !! GOT IT GOT IT GOT IT !!!!! It's the damn (-) on the battery that needed cleaning :P GOT IT !!! loll
musker
Oct 1, 2015 05:58 PM
pfsantos
Sep 30, 2015 01:29 PM
Devon Murray
Sep 25, 2015 09:41 AM
subeone
Sep 24, 2015 09:58 PM
