crap Armor ALL on my gauges!
Old Aug 9, 2003 | 02:01 PM
alexander's Avatar
a couple of days ago my wife sprayed 'armor all; (actually turtle wax 2001) on my dash and it got all over my FD gauges!! she meante well and i thought not too much about it, till i tried using the following 1.window cleaner 2. rubbing alcohol 3. and Fast orange cleaner...oh and then i went to checkers and got Mewguires plastic cleaner adn they all didnt work... *****...any suggestions???
Old Aug 9, 2003 | 03:49 PM
Mahjik's Avatar
Mr. Links
Order a new gauge cover. The gauge cover is plastic (it covers ALL the gauges) and that kind of stuff tears it up. You can get them for around $65 from Malloy Mazda.
Old Aug 9, 2003 | 04:43 PM
Vick's Avatar
Gabriel Gonzales = Crook.
Is this with the part with the chrome rings around the gauges?
Old Aug 9, 2003 | 04:57 PM
T88NosRx7's Avatar
man, why was your wife cleaning your car?
Old Aug 9, 2003 | 05:29 PM
Mahjik's Avatar
Mr. Links
Yep. It's all one piece.
Old Aug 9, 2003 | 05:51 PM
patfat's Avatar
Track junkie
I have heard paste wax works.
Old Aug 9, 2003 | 08:18 PM
2GSLSE's Avatar
It was too early to fix dinner
Old Aug 9, 2003 | 09:37 PM
alexander's Avatar
haha i wish too early for my george forman dinner ok thanks guess I'll order the new gauge coer (plastic)
any idea how to pop off the chrome rings or really just how to get to the plastic to swap it out?
Old Aug 9, 2003 | 10:17 PM
rjuge's Avatar
this week i'm driving...
really easy to swap out.
Remove three screws to take off the steering column surround. Pop out the side vent (by driver's door), remove two screws to remove the kick panel. Remove three screws (two bottom- one on top) to unbolt the cluster. Pull it out (snaps in the back). Disconnect all the plugs (8 and a bulb i believe) and take the cluster to a workbench.
Remove the four screws holding the cluster to the cover, then ou can unsnap the plastic cover.
When you're this route, you can try another way to clean it, but you're going to need rubbing compound and swirl remover. The idea is to use the rubbing compound to cut away the damaged plastic and then use the swirl remover to remove the scratches... Give it a try if you're gonna buy a new one...
GL, Rob
Old Aug 9, 2003 | 11:03 PM
Mahjik's Avatar
Mr. Links
It's all one piece. The plastic cover and the chrome bevels all together (or at least glued together).
Here's a pic of my old worn out one:
Old Aug 9, 2003 | 11:15 PM
Vick's Avatar
Yeah, I knew that they were one piece. I re-chromed my rings awhile back.
Old Aug 10, 2003 | 09:26 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
I tried re-chroming mine... No workie.. BUT: I have Autometer Gauges. I know... Autometer.... They've worked fine for me.
Anyway, the Autometers have the siver rim; not chrome. So, I removed the stock gauge Bezel and did it in the matte (sp?) silver. Looks pretty badass. I'll throw up some pics later.
Old Aug 10, 2003 | 01:13 PM
Vick's Avatar
Please do.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
