i have carb question
Old Aug 5, 2003 | 11:31 AM
minocqa's Avatar
Unhappy i have carb question
hi
i have a 1985 Gs 12a
when the car is cold it starts right up
after it warms up i still have to use the choke to get it started. and then if i do this to much it will flood. anyone have any ideas why this is happening?
thanks
Don
Old Aug 5, 2003 | 11:55 AM
Rx7carl's Avatar
Airflow is my life
If you give it a quick pump wit the gas pedal will it start easier?
Old Aug 5, 2003 | 08:17 PM
minocqa's Avatar
when i just pumping the gas pedal, it doesnt ever seem to start
i usally have to choke it. to get it started
Old Aug 5, 2003 | 08:29 PM
Rx7carl's Avatar
Airflow is my life
Hows your ignition system? Heat raises resistance and can cause a marginal ign sys to be weak. Also, have you changed your fuel filter lately?
On the carb itself, when its warm, before you try to start it, look and see where the float level is, you may be boiling out the fuel when its sitting after you shut it off.
Old Aug 5, 2003 | 08:38 PM
minocqa's Avatar
Hi Carl
thanks for the replies
this may sound dumb but how do i check and see if the floats are dry?
Don
Old Aug 5, 2003 | 08:40 PM
Rx7carl's Avatar
Airflow is my life
Theres windows on front and back sides (yours may be covered in years of crud). Look in the manual, youll see pics of them. The proper level is midway in the window with the car level.
Old Aug 5, 2003 | 08:48 PM
minocqa's Avatar
Hi carl thanks again
i'll check it tomorrow
could you give me your email address
i would like to send my carb in for you to rebuild this fall
thanks
DOn
Old Aug 5, 2003 | 09:10 PM
Rx7carl's Avatar
Airflow is my life
Just in case DC871@aol.com
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
