Sponsored by: CARiD
low power output on dyno rx-8s
Old Aug 1, 2003 | 02:11 PM
fknamerican's Avatar
Newbie
while dyno testing the rx-8 be sure to disable both the DSC and the TCS to do this follow the order below
1 start engine
2press and hold the DSC switch on the left of the steering column keep prseeing till BOTH of the DSC and the TCS lights stay on (the TCS light is located in the tachometer and has a sighn of a car going sideways)
3do not turn key off or it will enable both systems and you will have to repeat the procedure
Good luck hope this helps the power output post replies after doing the above procedure and dyno testing oh be sure you wait till at least 1000 miles before doing this to assure proper break-in
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
dkwasherexd
May 27, 2017 04:51 AM
