Broken Powerplant Frame?
Old Sep 16, 2001 | 04:27 PM
Marshall's Avatar
Hey guys,
What are they symptoms of a broken PPF? I got a lot of wheelhop on one run and the next time I tried to do a burnout I heard a clunk and it was very difficult to spin the tires. There is no noise coming from the diff and it drives fine. Is there a common place where these things break?
Old Sep 17, 2001 | 01:25 AM
jackc's Avatar
Hey Marshall,
Mine broke on the top/front that connects to the frame I beleive,
Check out where it connects to the tranny as well. I just got mine Welded togethor but I think you should get the Mazdaspeed one. I've heard it's indestructable.
Sorry i don't know what effects it would have if it's broken...
Probally a slight loss of power to the ground. And a slghtly loose
feel around corners. best wishes though... jc
Old Jan 27, 2003 | 07:13 PM
gohorns's Avatar
anyone know the symptoms
Old Jan 27, 2003 | 07:48 PM
RTS3GEN's Avatar
The Man
They basically break wherever they are weak. I did the exact thing, tried to launch but couldn't accelerate, the damn ppf broke and the drive shaft u-joint was hitting the E-brake cable mount above the drive shaft. Was also allowing the big ET streets to rub the under side of the fender as well as made the clutch slip like hell because of everything making contact with the car(tires/ fender -drive shaft/cable mount and this was making the clutch slip) Yes, Marshall it sounds like you've busted the PPF. The mazdaspeed one is like 350 bucks but I believe it is very tough. I have many 1.70 60' times on ET streets with mine and a few Mid 11 second runs with no problems on mine.
Art
Old Jan 27, 2003 | 08:36 PM
Bucrx7's Avatar
The mazdaspeed PPF is 10% stronger then stock. The Re-Amemiya is 20% stronger then stock so if you do the math the RE one is stronger then the mazdaspeed.
Old Jan 27, 2003 | 08:46 PM
Chronos's Avatar
I'm kinda slow Bucrx7...maybe you could work it out for me?
Old Jan 27, 2003 | 10:01 PM
c00lduke's Avatar
Where can you find the The Re-Amemiya one?
Old Jan 27, 2003 | 11:01 PM
Bucrx7's Avatar
Jt imports. Maybe Jason from the Rx7store can get ahold it it.
http://www.jt-imports.com/RE%20Amemiya%20FD.htm
Old Jan 27, 2003 | 11:45 PM
airn's Avatar
rxecret7.com sell a ppf made by Sanai for 350 dollars. the mazdaspeed one if you ca find on in the states is going to be marked up well above $350. i know because i called everywhere and they cant get them imported and the ones they have left over they are selling for 500.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
pfsantos
Sep 30, 2015 01:29 PM
