Silly Question - easy answer?
Old Jul 31, 2003 | 05:13 AM
Bayce's Avatar
Question Silly Question - easy answer?
As I have only had my beautifully loved 7 for a month, and got no manual, a few silly questions answered would be of great help!
1 - my water washers dont work (Need new motor) but where is the switch that squirts the head lights?
2 - same for the rear washer - I found the wiper but NOT the washer ??
3 - you know the clear plastic that covers the rear tail light assembly ? Does it come off - easily? There is so much dirt build up in there I would love to clean it - dont wanna break lens cover!
Sorry to ask such dumb questions - but really like to know - plus - cant find out anywhere!!
Old Jul 31, 2003 | 08:36 AM
Rx7carl's Avatar
Airflow is my life
http://www.wankel.net/~krwright/cars/rx7/wiring.html
online shop manual.
Old Jul 31, 2003 | 08:48 AM
Bayce's Avatar
Ahhh... cool !! _ Just whatI have been looking for ! Thank you!
Old Jul 31, 2003 | 08:50 AM
RXTbone's Avatar
1) Never seen an 1st Gen with headlight washers
2) The same switch that operates the rear wiper, operates the washer - push the toggle switch forward
3) There's 6 or 8 nuts that you need to remove to release the rear tail light lens. You can access them through the rear hatch carpet - I think they're 10mm nuts.
Take the time to run down a Mazda Shop Manual - as opposed to Haynes or Chilton (though they're better than nothing). You can usually find one on Ebay for about $15.
Good luck!
Old Jul 31, 2003 | 09:40 AM
excitingleopard's Avatar
Prosthetic head.
Actually, you don't need to remove any bolts or nuts to get the lens off. To remove the entire taillight assembly, remove those bolts. If you just want to remove the lens, basically just pull it off. There are some clips on the outermost side of each light lens, but the rest is held on by glue. You'll have to reglue it.
Old Jul 31, 2003 | 11:18 AM
O 16581 72452 5's Avatar
The infamous number guy!
I'd suggest just buying new taillights from a junkyard, pulling the lens off is very tedious. The lens are VERY brittle.
Old Jul 31, 2003 | 11:21 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
online shop manual.
Ouch! Definitely not 56K friendly.
Old Jul 31, 2003 | 12:07 PM
Rx7carl's Avatar
Airflow is my life
Hey, but its free! Instead of trying to open it, before you go to bed, right click and "save as". Then its on your hard drive for quick reference.
Old Jul 31, 2003 | 04:15 PM
REVHED's Avatar
Hunting Skylines
Re: Silly Question - easy answer?
The washer switch is on the centre console. It's the same switch for retracting the headlights. Basically the switch has an on/off position for retracting the lights as well as a push button function for the washer.
Old Jul 31, 2003 | 05:34 PM
85gsl2ndtimearound's Avatar
Are you guys saying ther u is a headlight washer on a 7?
Old Jul 31, 2003 | 05:44 PM
Keaponlaffen's Avatar
yeah, Canadian and Australian models I believe came with headlight washers. They're little black things that stick out from the front bumper, and spray the headlights with washer fluid...
Old Jul 31, 2003 | 07:21 PM
Bayce's Avatar
Yes, mine is a Series II gen 1 (1983) 7. It has headlight washers on the bumper. Buy new tail assembly? Youch, have you tried buying spares for 20 year old cars in Australia - and it still leaves me with the job of removing the clear plastic assembly and putting it back on. And yes, that wiring manual is HUGE - my thing keeps freezing trying to get it. Thanks for all the input though!
Old Jul 31, 2003 | 10:10 PM
specRX7_22's Avatar
me neither. i thought that was a german thing hmm..
Old Jul 31, 2003 | 10:46 PM
mwpayne's Avatar
Admitted 'rexaholic'
About the rear taillights, I've had only one way work on getting them apart without cracking them.
Go to an auto paint store and get a pint of solvent..I forget the name, but it's used to dissolve any kind of glue or adhesive. I used it initially to remove tint from the rear window, but I found if you remove the taillight assembly and squirt this stuff in the groove where the clear lens is glued to the housing, wait overnight, the clear lens will come off. Work slow and carefully, pulling with your fingers. It'll also help to run a razor blade around the groove first before you start pulling.
Good luck!
BTW, it's worth it, the lights will look 100% better after, it's amazing how much crud works its way in there after 20 years.
_Tones_
May 25, 2021 05:37 AM
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
galvatron10000
Canadian Forum
Sep 8, 2015 08:50 PM
