fuel problem
Old Jul 30, 2003 | 11:37 PM
Csefiroth0's Avatar
fuel problem
hey dudes
i recently did the 10w-30 to 20w-50 switch since im in hot weather, but the car is getting horrible gas mileage after the change (like half a tank for only 70 miles). a friend told me my fuel injectors need to be cleaned... (by the way i accidently added too much oil and had to drain some.) so i hope someone can give me a diagnosis.
thanks for your time!
c
Old Jul 30, 2003 | 11:46 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
try changing you fuel filters (one in the front and one in the rear hatch) and also your air filter if you havent already. How bad was your gas mileage before?
Old Jul 30, 2003 | 11:56 PM
Csefiroth0's Avatar
the fuel filter is fairly new. i was getting normal gas mileage before the freakin oil change!
Old Jul 31, 2003 | 10:55 AM
Csefiroth0's Avatar
any other suggestions?
Old Jul 31, 2003 | 01:52 PM
Doesn't really sound like it would be related to oil.
Old Jul 31, 2003 | 03:39 PM
Csefiroth0's Avatar
could i have knocked something loose while changing the oil filter?
Old Jul 31, 2003 | 04:41 PM
fill your tank and drive it 70 miles then fill it up and see how many gallons it took. Most turbos get like 12 miles per gallong. czu mine reaches 70 miles on half tank so i'm use to it and i changed both fuel filters and air filter
Old Jul 31, 2003 | 04:47 PM
Csefiroth0's Avatar
my car is an 88 gtu (non-turbo) so i should be getting way better mpg than this.
i don't understand.. it is such a drastic change! i'm afraid to drive it now!
Old Aug 1, 2003 | 08:59 PM
Csefiroth0's Avatar
im gonna change the fuel filter and o2 sensor and see what happens.
thanks though
-c
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
