Where does the tachometer get its signal from?
Old Jul 29, 2003 | 07:45 PM
eyeoutthere's Avatar
I am trying to make some RPM activated switches, but I need to know where to get my signal from.
Some info on what the signal will look like would be helpful as well.
Thanks,
Jason
Old Jul 29, 2003 | 07:46 PM
wpgrexx's Avatar
leading coil, I 'll go look for you on my car if you want, but you should look in the fsm.
Old Jul 29, 2003 | 07:47 PM
RETed's Avatar
Actually it taps off the trailing coil pack...
Either trailings or leadings have a female bullet connector which you can tap for a tach signal.
-Ted
Old Jul 29, 2003 | 07:51 PM
Icemark's Avatar
Ted is right, all electronics (like cruise, gauges, power steering, etc) requiring a tach signal in the FC get the tach signal from the trailing coil pack
Old Jul 29, 2003 | 07:56 PM
My tach starting not working properly, so I took it down to the mechanic, he said that it was the leading coil. there are actually two leading coils and an ignitor. each leading coil is $125, and the ignitor is $500 OEM. you can also buy it in a package... not sure on the cost.
Old Jul 29, 2003 | 07:57 PM
That was fast
Do any of you know what the signal looks like?
Thanks guys.
Old Jul 29, 2003 | 08:10 PM
RETed's Avatar
Standard tach signal, which is a "pull down" square wave.&nbsp Sorry, I can't give you duty cycle or pulsewidth times...
-Ted
Old Jul 29, 2003 | 08:26 PM
Duty cycle is no big deal.
So it is just a simple square wave?
Old Jul 29, 2003 | 08:47 PM
RETed's Avatar
Yes, like most tach signals, it's a "negative" square wave...
-Ted
Old Jul 29, 2003 | 11:47 PM
HAILERS's Avatar
HAILERS
stock7....ditch your mechanic. He's taking you for a buggy ride. See http://www.teamfc3s.org/info/articles/demystifying.html and or the schematic https://www.rx7club.com/forum/attach...postid=1398836
Old Sep 2, 2003 | 08:33 PM
-Ted
Cool.
Howmany Pulses per revolution? 3? 6?
Old Sep 2, 2003 | 08:39 PM
J-Rat's Avatar
Alcohol Fueled!
I believe the trailing pulses are 3 per full revolution.
Old Sep 3, 2003 | 12:52 AM
NZConvertible's Avatar
I'm a boost creep...
Yep, fire that mechanic, he's very wrong. The tach is driven by the trailing coil as mentioned; plus the leading coil is one double-ended coil with one ignitor. It's the trailing coil that's actually two seperate coils with two ignitors.
Old Sep 3, 2003 | 02:02 PM
RETed's Avatar
Originally posted by eyeoutthere
Cool.
Revolution of the e-shaft?&nbsp One.
Revolution of the rotor?&nbsp 1/3rd.
It fires like a 4-cylinder, I believe, so it's one pulse per 1 RPM.
-Ted
Old Sep 3, 2003 | 07:54 PM
Are you sure?
How many times does any one spark plug fire per revolution of the e-shaft?
Once right?
Old Sep 4, 2003 | 03:21 AM
A single rotor fires once per revolution. So a 2-rotor fires twice per revolution, same as a 4-cyl.
Devon Murray
Sep 26, 2015 08:15 AM
