recent problem
Old Jul 29, 2003 | 02:06 PM
marshp's Avatar
Registered Rx7 Owner
recent problem
hey there i recently have been having a problem with my 87 TII
sometimes it seems that the stereo will cut out, and i dont mean like the subs or the amp, like the radio will cut out and skip as if it was a cd player but its not
as well while that is happening my car starts going beep beep.... beep beep..... beep beep
i have no idea what could be the cause of either, and i already tried searching
and ideas would be greatly appreciated
thanks
marshall
Old Jul 29, 2003 | 02:13 PM
Aaron Cake's Avatar
Engine, Not Motor
More then likely the standard cold solder problem in the stereo. Also, before you pull apart the stereo, check the wiring harness for frays or tears.
Old Jul 29, 2003 | 03:00 PM
marshp's Avatar
ok now iv got the stereo problem down to when i turn on my headlights it is the only time that the stereo cuts out and it seems to work with the headlights down jus fine
also i noticed my dome light doesnt work but it used to
Old Jul 29, 2003 | 03:06 PM
marshp's Avatar
also i noticed that on the display for all the lights, the "hatch" light it always on and im sure its closed
some weird electrical problem somewhere unfortunately but im not sure where
Old Jul 29, 2003 | 03:09 PM
Fitness Stain's Avatar
Yar-Har-Har
my hatch light used to stay on too....
i would have to reopen it, crack a window and slam it....
it would latch before, but if no windows were down up front the pressure i guess would not let it close all the way
Old Jul 29, 2003 | 03:26 PM
Aaron Cake's Avatar
Engine, Not Motor
I still believe it is a problem with the stereo itself. The hatch light is probably just incidental.
Old Jul 29, 2003 | 04:41 PM
You may also want to try wiggling the key, I have ran into a couple different 7's that the ignition switch was wearing out in. the sun roof wouldn't close, and the stereo would cut in and out. just a suggestion...
Old Jul 29, 2003 | 06:34 PM
Icemark's Avatar
Have you checked your dome light (room) fuse yet???
C. Ludwig
Jan 30, 2019 06:31 AM
REsuper7
Aug 31, 2015 09:19 AM
