2 most important guages???
Old Sep 15, 2001 | 10:22 PM
JoeD's Avatar
...not including a boost gauge, which 2 other gauges are good to have??? (2 gauges OTHER than a boost gauge)
which ones?? EGT?? A/F?? Water temp.??? Oil temp.?? etc...
Old Sep 15, 2001 | 10:28 PM
vosko's Avatar
Just Call Me Terminator!
i would say water temp.. if an engine fails it is usually due to overheating or overboosting
Old Sep 15, 2001 | 10:52 PM
Tad's Avatar
Tad
i'll second that one,
when my engine popped, if i had a boost, and temp guage(my stock temp guage was busted) i woulda been saved!!
i cant believe the FD doesnt come with a boost guage,
my friends old *** crappy turbo volvo even has a stock boost guage!
Old Sep 15, 2001 | 11:15 PM
Zoomspeed's Avatar
Other then a boost gauge I would say a water temp and an a/f gauge.
Old Sep 15, 2001 | 11:36 PM
evot23's Avatar
Classy
In this order
Water temp
A/F
EGT
Old Sep 15, 2001 | 11:42 PM
DK's Avatar
DK
40k worth of fail
I'm not sure why people are saying A/F guages. Those things literally aren't worth a ****, especially on a MAP-based fuel system. Those things flicker back and forth qualitatively and quite inaccurately. Really they're just fancy lights for riceboys. Well, most of them. I think GReddy may be the manufacturer of the one worth a nut.
An EGT guage will tell you so much more if you know how to use it, but you have to get one hot enough for a rotary (GReddy, A'PEXi, BLITZ, etc.).
Old Sep 16, 2001 | 08:16 AM
sokudo's Avatar
gauges
egt and water temp. a/f are not very accurate unless you get a very high end one like $600 to $800 one.
Old Sep 16, 2001 | 10:16 AM
1FAST7's Avatar
Is it better to have both EGT and A/F or just EGT??? what does EGT show???
1FAST7
Old Sep 16, 2001 | 11:09 AM
0piston's Avatar
Don't even bother with a A/F meter. I'll paraphrase exactly what Sokudo said, they just have pretty lights. The only time an A/F gauge gets critical is under boost, and the only pricisely acurate ones are the expensive ones i.e. uego, lambda.
The EGT gauge shows how "happy" your engine is. If a your engine is running lean it will show it as a high temperature reading and vice versa.
1FAST7
Old Sep 16, 2001 | 12:03 PM
dis1's Avatar
www.silverbulletrx7.com
I must disagree that an A/F gauge is worthless. They aren't perfectly accurate but they are enough so that if you are running lean for some reason you will notice. EGT is Exhaust temp and is useful to some degree but if you are running lean (causing higher exhaust temps) the gauge won't instantly react like an A/F will. Although I don't have direct experience with EGTs I would expect that it would take time for the average temp to rise in the sender meaning that the gauge won't react fast enough. Thus pop goes your motor before your gauge shows something. I would therefore chose water temp, then A/F (and I have) and then maybe oil temp. It is a good indicator of your engine's risk as well. It will change faster than water temp and is also effected by exhaust temp because oil cools our turbos to some degree and they are naturally driven by exhaust gasses.
Old Sep 16, 2001 | 12:07 PM
Mudd's Avatar
I'd have to second the vote on the EGT. If you're running too lean, an EGT could be your last saving grace before detonation...
Old Sep 16, 2001 | 01:04 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
i'm voting egt over a/f as well.
Old Sep 16, 2001 | 07:00 PM
JoeD's Avatar
Re: gauges
yeah....and the only affordable A/F guage is the Autometer...
Old Sep 16, 2001 | 07:23 PM
Zoomspeed's Avatar
Re: Re: gauges
Isn't the Greddy A/F gauge only $200-$300? And its pretty accurate is it not?
JoeD's Avatar
does the DEFI measure hot enough for rotary temps??
Old Sep 17, 2001 | 07:19 PM
JoeD's Avatar
aslo, the greddy and apex EGTs go up to 1200 C. what does the DEFI go up to?? it says 20, so is that 2000 F??
what does 2000 degrees F = in C??
Old Sep 17, 2001 | 08:29 PM
suganuma's Avatar
no
so what are good/bad EGT temps to have???
any relation of temps to specific a/f ratio numbers??
thanks
Nic
Old Sep 17, 2001 | 08:31 PM
DK's Avatar
DK
40k worth of fail
2000 F is ... ummm ... do math (2000-32)*(5/9) = 1093 C.
0piston you could also paraphase what I said, which Rob (sokudo) essentially repeated.
By the way Rob, have you seen the "secret site" yet? If not, get Alf to show you or send me a PM.
Old Sep 17, 2001 | 11:56 PM
spyfish007's Avatar
Yellow Dragon is no more
EGT over AF because AF is really just your O2 sensor reading and if you have ever caught any discussions on O2 sensor dyno tuning you will know what this is really useless. The EGT should respond quicker. The hotter the temps the leaner the engine is. I believe rotary engines are in the 1650F range? I am waiting till I go single to add an EGT, so I can't varify till then. The idea is that you can watch it and compare it to its normal motion kind of like your boost gauge.
Old Sep 18, 2001 | 12:01 AM
Poweraxel's Avatar
other than a boost gauge:
1. water temp gauge
2. fuel pressure gauge
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
