which injectors are the right ones?
Old Jul 28, 2003 | 09:22 PM
ok i can buy one of two sets of injectors, the guy said he knows one set is low imp. which would fir my na s4 and the other is high, he said the numbers on the first set are 529, and on the second 195500-1350. which set would be the correct ones? TIA
Old Jul 29, 2003 | 01:41 AM
NZConvertible's Avatar
I'm a boost creep...
86-87.5 cars had low-impednace injectors (and a resistor pack), 87.5-91 cars had high-impedance injectors.
Old Jul 29, 2003 | 02:07 AM
hypntyz7's Avatar
http://www.rotaryresurrection.com/injector.html
Old Jul 29, 2003 | 11:04 AM
HAILERS's Avatar
HAILERS
Your car is a 87 and it's a non-turbo. So your car should get one of two choices depending on the chassis number. IF your chassis is below JMIFC331 H0500001 550199 then you get low impedence injectors of approx 2.2 ohms, part nunber 195500-1350
If the chassis number is above the one listed above....you get high impedence injectors of approx 12 ohms.
So go look at your chassis number........on look and see if your car has a solenoid resistor located on the fender below the air filter assy. It's silver in color, approx four inches long, one and a half inches wide. Held down with two ten mm size nuts. Free online factory service manual at http://www.iluvmyrx7.com unfortunatly they don't have a 87 manual (best of the RX series cars) so you can't see an illustration of the solenoid resistor there. That item can be seen here: https://www.rx7club.com/forum/attach...postid=1320242 God willing the site will support that jpg.
Old Jul 29, 2003 | 11:08 AM
HAILERS's Avatar
HAILERS
OH. It's most likely the 529 set is an aftermarket set from Beck/Arnley. Just get a meter out and ohm out the two pins on the injector and see if its 2 ohms or approx 12 ohms.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
