EGR block-off plate ?
Old Jul 28, 2003 | 04:15 PM
Question EGR block-off plate ?
Have any of you blocked off the EGR port on the LIM? Here is a pic with the EGR on.
Old Jul 28, 2003 | 04:18 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Yup! Block that sucker off!
Old Jul 28, 2003 | 04:23 PM
Just take it oof and cover the open ports?
Now one with it off.
Last edited by mar3; Sep 4, 2010 at 03:21 PM. Reason: Merged back-to-back posts...
Old Jul 28, 2003 | 04:36 PM
ejmack1's Avatar
Lawn Ornament
dude thats your ACV ****... not your EGR
Old Jul 28, 2003 | 04:37 PM
ejmack1's Avatar
Lawn Ornament
drive down to K2RD and pick up a block off plate kit.... probably about 1 hr drive
Old Jul 28, 2003 | 04:52 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Haha! I guess I should open the picture from now on!
Old Jul 28, 2003 | 04:56 PM
JONSKI's Avatar
5yr member, joined 2001
Damn, I go take a **** and ejmack1 beats me to the punch before I reply. jdhuegel1, shame on you for mis-informing. This almost as bad as the time I told ejmack1 that the recall fan relay was the AT-ECU.
Anyways, this is where the EGR is:
Here is why we eliminate it:
Old Jul 28, 2003 | 04:59 PM
ejmack1's Avatar
Lawn Ornament
hey focker i forgot about that, and I never have found out where the auto ecu is located...
Last edited by mar3; Sep 4, 2010 at 03:22 PM. Reason: Killd quote since reply was back-to-back to post in question...
Old Jul 28, 2003 | 05:26 PM
How much is the kit? I am tring to save money on parts and can make my own plates I am just trying to learn which I can block off.
I wont to get rid of everything that I dont need. I am not concerned with emisions.
Thanks for your help
Old Jul 28, 2003 | 05:32 PM
JONSKI's Avatar
Dude, it was SOOO my bad. It happened right after you did the tranny conversion and you were (and still kinda are ) my superhero, so I tried to help you without thinking.
I'm an assclown!
Old Jul 28, 2003 | 05:36 PM
JONSKI's Avatar
How can you not be concerned with emissions when you live in the people's republic of California?
Since you already have a PowerFC, you can potentially eliminate a lot of crap without worrying about any ill-effects. With a midpipe, your ACV, airpump and a bunch of solenoids immediately become useless.
Other stuff you can eliminate:
TB coolant lines cold start cam elimination
ISC elimination
AWS
half the solenoids on the rack
etc...
Old Jul 28, 2003 | 06:06 PM
Thanks thats what I was getting to. I wasn't researching anything yet and the exhaust carbon in the port made me beleive that it was EGR. Thanks for the insight. I am getting rid of a lot of stuff. Thanks again
OH yeah. Emissions. My car is not registered in this state. (Thank God)
Last edited by mar3; Sep 4, 2010 at 03:23 PM. Reason: Merged back-to-back posts...
Old Jul 28, 2003 | 06:29 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Gotta love the military!
Old Nov 30, 2009 | 04:30 PM
s1mpsons's Avatar
HamfistRacing.com
does the ypipe have to come off to get the egr off for block off?
Old Nov 30, 2009 | 05:29 PM
TpCpLaYa's Avatar
T3DoW
I would say yes...to make things alot easier
Last edited by mar3; Sep 4, 2010 at 03:23 PM. Reason: Killd quote since reply was back-to-back to post in question...
Old Dec 9, 2009 | 07:53 PM
s1mpsons's Avatar
HamfistRacing.com
The EGR block off plate I have is not thick enough to retain the OE nuts without using 8 washers. Am I supposed to remove the stud and use the bolts provided with my block off kit? Also, can I reuse the old gasket?
Old Dec 9, 2009 | 08:25 PM
Mahjik's Avatar
Mr. Links
Use bolts. Skip the gasket and just use some RTV.
Last edited by mar3; Sep 4, 2010 at 03:24 PM. Reason: Killd quote since reply was back-to-back to post in question...
Old Dec 9, 2009 | 10:19 PM
s1mpsons's Avatar
HamfistRacing.com
To remove the studs just put the nuts back to back and back out the inner nut? What is the stud thread size/pitch?
Old Dec 9, 2009 | 10:23 PM
widebodyseven's Avatar
Formerly widebodyseven
I just use some pliers to take the stud off or use a drill lock it on to the stud and pull the trigger.
Old Dec 9, 2009 | 10:33 PM
s1mpsons's Avatar
HamfistRacing.com
I'd prefer not to mangle them incase I need to revert back.
Old Dec 10, 2009 | 10:12 AM
theorie's Avatar
AponOUT!?
yeah...that first pic isn't the egr.
anyway, i ghetto-fabbed a block-off plate. it worked.
when i pulled my motor for porting/rebuild i bought a block-off plate kit so i could get rid of everything that wasn't needed.
Old Dec 10, 2009 | 10:19 AM
s1mpsons's Avatar
HamfistRacing.com
Looks like you just used two oversized nuts as a large washers (rather than stacking washers like I did).
Last edited by mar3; Sep 4, 2010 at 03:25 PM. Reason: Killd quote since reply was back-to-back to post in question...
Old Dec 10, 2009 | 11:13 AM
Mahjik's Avatar
Mr. Links
Yes, use two nuts back to back to remove the stud. Just take the stud to your local hardware store to find a matching bolt. That size is used all over the engine bay, so I keep a big bag of those around for replacements.
Old Dec 10, 2009 | 11:27 AM
s1mpsons's Avatar
HamfistRacing.com
M6 Pitch 1, most likely. I already have a million of them, but sometimes stud use odd threads. Ok. Thanks!
Old Feb 25, 2010 | 09:16 PM
Captain_Panic's Avatar
Back in the BOOST Game
I am about to remove my ACV and EGR (bought the block off kit from Banzai). What do I do with the open vacuum lines? Do I just put a nipple on the other end and zip tie it to close it off?
