battery relocation to rear bins
Old Sep 15, 2001 | 06:36 PM
suganuma's Avatar
no
do you have to cut the bins to fit an optima battery in there??
i know several people have dont this using the optima batteries....just doesnt look like it would fit right out.
what do i need to do?
where did you run the ground from the battery to??
and how did you do the connections at the engine bay - grounds and connections to that fuse box.
thanks
Old Sep 15, 2001 | 08:54 PM
DK's Avatar
DK
40k worth of fail
Shouldn't you know all about battery stuff, duracell719?
Old Sep 15, 2001 | 10:08 PM
puma's Avatar
canadian monster
ok i don't know much about rx7 so i ask a lot of question and everyone always answer. I know about battery relocation thought so i will help you.
Yes, you do have to cut the bin to use the optima.
i got my ground on the same ground as the switch for the door that says if it is open or not. Undo the side panel and you will understand what i am talking about. You just need to be sure the contact is good by sanding the paint.
the connection on the engine bay is quite easy, just undo the positive battery connection and you will see that there is a screw, just tap the connector (that you will buy to put at each end of the wire you are going to run from the little fuse box to the battery inside the car) to that screw.
Old Sep 16, 2001 | 12:10 AM
evot23's Avatar
Classy
I took the positive line out of the engine bay and connected it to the starter.
Old Sep 16, 2001 | 03:36 PM
BrianK's Avatar
all the info you need:
http://www.rx7turboturbo.com/robrobi...re_battery.htm
Old Sep 16, 2001 | 04:46 PM
wptrx7's Avatar
Newb Photog
where in the firewall do you run the positive cable?
luigi
Old Sep 16, 2001 | 04:56 PM
suganuma's Avatar
no
im just going to run it through the same hole as the hose for my boost gauge. its right by the power braking HUGE black..thing...i forget what its called. need to take that off one day.....
anyways.....on rob's site it doesnt comment on wire routing or the connections at engine bay, which i still have questions about.
thanks yall
Old Sep 16, 2001 | 06:07 PM
1QK7's Avatar
I also have questions about the wiring? is there any site that does a walk though from start to finish??
Old Sep 17, 2001 | 07:05 AM
puma's Avatar
canadian monster
trust me on that one, remove the inner plastic fender on you front driver wheel, you will understand where to pass the wire without drilling any hole in the firewall.
puma
Old Sep 17, 2001 | 09:39 AM
evot23's Avatar
Classy
Puma is right on that one!! The hole is huge and will save you some trouble if you are anything from the engine bay to the inside.
Old Sep 17, 2001 | 08:38 PM
suganuma's Avatar
no
im wondering about the underhood connections at the fuse box connecting to the positive terminal and the ground that usually goes to the engine. what do i need to do with them??
thanx
Old Sep 17, 2001 | 10:10 PM
alwan16's Avatar
thanx
if you connected the positive to the starter then just take apart the fuse box by taking out those little bolts and nuts and taking out the metal piece that extends out to hold the metal piece that goes to the battery post. you can take out the negative wire by unbolting it (i think) but i just cut it off at the very bottom where it connected to the chassis.
Old Sep 18, 2001 | 01:01 AM
1QK7's Avatar
ok I have the wires ran now all the way into the bins. Its not that bad it took me about 1 hour to run the wires.Now for the fun part i would like to use an optima battery but im not sure if it will fit. I DO NOT want to cut the bins what battery
will fit without cutting.
Thanks
Old Sep 18, 2001 | 01:21 AM
alwan16's Avatar
odyssey pc925 was what i used. i'm sure it'll fit w/o cutting but i don't know how you are going to run the wires w/o cutting.
Old Sep 18, 2001 | 09:43 AM
1QK7's Avatar
I cut to small round holes in the bin to run the wires i just dont want to have to hack the **** out of it fit the battery.Thanks
rotor_veux
46
Jun 12, 2018 10:39 AM
