who can build me a turbo
Does anyone know where i can have a turbo built? I was thinking about buying a TO4R, and i still am, but HKS is so damn expensive. I'm looking for high numbers. The T51 KAI was another thought, but i figured that was overkill. Among others are a T-66, TO4S, TO4E, or maybe you guys have other suggestions. It will be driven on the street, but not a daily driver per-say. I want good power at 1 bar (~400ps) on pump gas. I know these turbos are for higher boost, and they will be used for that as well on higher octane/racing fuel where im really looking for good numbers (into the 550-600+ps range). A 1.15 A/R turbine housing sounds good to me so far. Spool time i would like around 3500/4000 rpm, maybe a little higher if it has to be. If you guys have any suggestions or can help me out, it would be much appreciated.
