how do u remove the primary injectors from the fuel rail??
Old Sep 15, 2001 | 02:53 PM
Bacon's Avatar
IRS 4 Life
ok i got the rail out to send them to rc to get cleaned and stuff...but how do i get them out of the rail..or do i just send the whole deal to rc and theyll take care of it??
thanks
Old Sep 15, 2001 | 07:07 PM
vosko's Avatar
Just Call Me Terminator!
i need a BLOWTORCH STAT! jk dunno
Old Sep 15, 2001 | 07:35 PM
Rx7aholic's Avatar
I think if i recall there are two screw's that hold the injector holder. Then u removed the holder and the injector with a little force. Also make u mark each injector because rc do not do it for u.good luck
Old Sep 16, 2001 | 01:22 AM
Bacon's Avatar
IRS 4 Life
i took all the screws out...but they wont come outa the rail...mabe ill use the persuader.....aka mallet to help them along...
Old Sep 16, 2001 | 11:00 AM
Flybye's Avatar
It's never fast enough...
You need to twist them back and forth and pull them slowly out. Try applying some 2-cycle oil into the o-rings or spraying some WD40 on it. This should help loosen em up a bit. They injectors are always VERY tight on there.
