Can the OMP get stuck open?
Old Jul 23, 2003 | 07:07 AM
RotaryNotary's Avatar
Question Fixing a stuck (open) OMP
Going for my clean air, and they won't even start the test due to too much blue smoke.
I've been told that my OMP is stuck in the open position by a different garage, but the only concern was too much oil being burned.
The non-problem has turned into a problem thanks to the clean air inspection; I'll lose my plates in 6 days!
I've searched the archives but found nothing of help on a first gen.
2 questions:
1) Anyone know of any quick/easy things to check, or have any fixes (other than disconnecting it and running two-stroke)
2) If no answer to 1), does anyone know whether FB OMP = FC OMP? I might be able to pull some info from the 2nd gen site.
Old Jul 23, 2003 | 07:29 AM
inittab's Avatar
I read your email
Yes, the OMP can get stuck open. I'd suggest that you rebuild the pump. It's an easy job that you or your "mechanic" can do. Give Mike Lowe a call at http://www.loweperformance.com/ . He has all the parts and instructions on how to do it. It'll cost 10 bucks for so.
The FC pump will not fit on your FB.
Old Jul 23, 2003 | 08:40 AM
1st to 3rd's Avatar
If you are in a big time crunch, then just unhook the OMP for the emissions test. Running w/o it for a few minutes isn't going to hurt anything.
Like inittab said, fixing your problem correctly is a simple task.
Old Jul 24, 2003 | 10:25 AM
As an aside to my original question, why is the Oil Metering Pump called a MOP not an OMP?
Old Jul 24, 2003 | 10:52 AM
enigma32's Avatar
hehe, I've wondered that myself....
And it would make life more amusing too =)
"I've got a problem with my MOP...."
Edit: Er, wait, I read that wrong... It *is* an OMP, not a MOP
Old Jul 24, 2003 | 03:02 PM
When searching, I found 301 hits on MOP, but 1648 for OMP, so I guess OMP carries the day.
I had seen MOP used so much in recent threads that I assumed that MOP was the official Mazda TLA
(TLA = Three Letter Acronym)
20B Forum
21
Mar 22, 2022 01:00 PM
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
