Error Codes WILL NOT GO AWAY. (Removed Air Pump & 30, 33, 39 error codes appear)!!!!
Old Sep 14, 2001 | 08:54 AM
neoanderson's Avatar
Error codes received:
30 - Split Air Bypass Solenoid open or short circuit
33 - Port Air Bypass Solenoid open or short circuit
39 - Relief 2 Solenoid open or short circuit.
A friend removed the air pump because we installed the TKT power pulley kit from Pettit and I'm wondering if these error codes have anything to do with it or are they an entirely different issue.
Since all of these solenoids go into the Air Control Valve I'm not sure if just removing the Air Pump would generate them. These are the only solenoids that even go into the Air Control Valve. I didn't do the work myself.... could it be possible that the Air Control Valve was removed along with the Air Pump???
Inquiring minds want to know. USA all the way!
'94 Touring Silver RX7 101000 miles (installed reman engine @ 100000)
Greddy CB
TKT cold air induction system
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
12abridgeport
Aug 17, 2015 06:28 PM
