Rebuilt Engine- hesitation on very light throttle?
Old Jul 20, 2003 | 12:27 PM
MURX's Avatar
Angry Rebuilt Engine- hesitation on very light throttle?
Got my new rebuilt up and running and trying to work out a few of the bugs. Right now on light throttle the car sometimes feels slugish, hesitant, and then kicks forward slightly as though it is misfiring and then firing fine. When accelerating there doesnt seem to be a problem and when decelerating there is also no problem that I can tell. It idles fine also. It is also not the 3800 RPM hesitation because I have not even taken the engine up that high because of breaking it in. I am thinking it might be the CAS might not be aligned properly because that was out of alignment when I first started it up and I couldnt get it to run. Any other ideas?
Also, I am just wondering is there a way to tell when the Mass Air Flow sensor is going bad? Mine seems to be clicking louder than it used to be. Cant remember exactly what it used to sound like since it has been a few months since I have drove it.
Oh, Another reason I am thinking it might be the CAS is because it seems to be running slightly hot. About 1/2 on the stock gauge (S4). I might be out in never never land with ideas so let me know what you guys think. I would like to get this fixed and put miles on it.
Old Jul 20, 2003 | 01:04 PM
r_ed_line53's Avatar
Cool
make sure your grounds are all there, usuall cause for hesitation or jerking.....
see ya,
car 53
Old Jul 20, 2003 | 02:55 PM
MURX's Avatar
I am pretty sure all my grounds are hooked up. Could splicing into the O2 sensor cause this a problem like this. Any other ideas?
Old Jul 20, 2003 | 05:27 PM
MURX's Avatar
ttt
Thanks
Old Aug 9, 2003 | 03:10 AM
your heating problem Have you change you radiator that might help heating ah.. as for the back firing how does you spark plugs look that could be it unless there new then good Q?
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
Microtech
30
Apr 23, 2016 06:37 PM
rxmiles
Aug 24, 2015 02:07 PM
