DIY wastegate
Old Jul 18, 2003 | 09:06 AM
GlennStile's Avatar
DIY wastegate
Hello guys.
Well i managed to pick up a loverly new turbo for my loverly new 13b engine but now im looking for a wastegate.
Considering i have a machine shop at my disposal i thought i might have a go at making my own. It's a pretty simple device but i thought i would ask if anyone had any experiance of doing this.
if your interested the turbo is :
Garrett T04 E64
P/N 465117 4275B
Compressor A/R 0.7
Turbine A/R 1.3
Cheers
Glenn
Old Jul 18, 2003 | 12:27 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
what style of wastegate are you planning to make?
Old Jul 18, 2003 | 06:43 PM
Directfreak's Avatar
I am a Jeeper Now.
Dude, just buy one. Don't re-invent the wheel. Check ebay for specials. A Wastegate is too important to "home-Depot" it. You could overboost, and pop your engine.
Old Jul 19, 2003 | 01:17 AM
BLUE TII's Avatar
Rotary Motoring
Have at it!
Another forum member just made his own as well. Not like it is hard if you know your way around a machine shop.
Just remember the materials it is made of are important as high rotary heat can fuse metals together a bit where the valve seals on the seat and cause overboost-especially if you use antilag. Most use a stainless valve and a cast iron seat/body, but the best use a special (high nickel?) stainless alloy for valve and seat/body or cast stainless alloy seat/body.
If you want the best WG you will probably have to buy one (Tial)- unless you have some real connections to get the alloyed stainless stock.
Old Jul 19, 2003 | 05:26 AM
HWO's Avatar
HWO
inteligent extratarestril
my wastegate was made by a automotive engineer who has all the right equipment at his disposal, he sells them off
Old Jul 20, 2003 | 08:22 AM
GlennStile's Avatar
Ok I'll answer your queries in order
82streetracer: Im planning on making ~40mm external wastegate.
Directfreak: but I want to make my own . I have made all sorts off stuff in the past from manifolds to pistons so a wastegate should be pretty easy really.
BLUE TII: any idea who the other guy was, maybe he would share some info ?? I already have some stainless valves which would be suitable 4n21 stainless which is about as heat resistant as you can go apart from sodium cored.
HWO: any idea what materials he uses ?? how much do they cost ?
cheers guys
Glenn
Old Jul 21, 2003 | 01:21 AM
HWO's Avatar
HWO
he uses Stainless Steel main body and piston, Cast alloy 'housing' the price - low enough to make all you americans cringe :P
i can take some pic's if you want
Old Jul 21, 2003 | 08:36 AM
GlennStile's Avatar
Pics would be grand internal pics would be even better but I doubt you'd wanna pull it apart.
does anyone make a external wastegate that works like an internal wastegate i.e. a hinged flap ??
Old Jul 22, 2003 | 10:39 PM
weaklink's Avatar
Resident Retard
I have heard that there are problems with stainless components cracking, as is the case with my apex kit. There is definately a leak in mine somewhere, but I can't say if it's a gasket, weld, or malfunctioning wastegate. Comes from the wastegate somewhere.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
