Sponsored by: CARiD
How to use a speed bleeder to change Tranny fluid?
Old Jul 15, 2003 | 02:35 PM
neo_omega's Avatar
***Moderator***
Question How to use a speed bleeder to change Tranny fluid?
anyone knows how?
Old Jul 15, 2003 | 02:39 PM
Hyperite's Avatar
Vagina Junction
Don't? I dunno what you're trying to do, Kenny, but you just take the drain bolt off, let 'er drain. Put bolt back on, remove filler bolt, and fill'er up!
Old Jul 15, 2003 | 03:35 PM
neo_omega's Avatar
***Moderator***
but the speed bleeder supposes to speed it up.
Old Jul 15, 2003 | 04:38 PM
Hyperite's Avatar
Vagina Junction
Link to product? I can't even imagine what it would do. The best thing to invest in is a big funnel and hose so you can fill the thing without spilling everywhere. A pump might be handy too, I just heat it up before filling so it pours like oil instead of a delicious DQ Blizzard.
Old Jul 15, 2003 | 05:33 PM
neo_omega's Avatar
***Moderator***
http://www.motiveproducts.com
Old Jul 15, 2003 | 06:54 PM
Hyperite's Avatar
Vagina Junction
That's for brakes, my man, not tranny.
edit: I suppose you could take the cap off and use it to pump the transmission fluid in...
Old Jul 15, 2003 | 08:24 PM
neo_omega's Avatar
***Moderator***
it said on the instruction that it can be use on tranny. But there isn't anything about how.
Old Jul 16, 2003 | 12:06 PM
Cosmo Donk's Avatar
Queer
I'm with Hyperite. I don't know how in the heck you could speed up the tranny drain Blow into the fill hole while it is draining I suppose
The tranny just drains out the drain hole, that's it. That contraption you have there is so you don't have to keep stopping to fill up the brake fluid. If you had that contraption and speed bleeders you could bleed your brakes in a jiffy!
Old Jul 16, 2003 | 04:41 PM
Hyperite's Avatar
Vagina Junction
Actually, this IS for bleeding brakes. The pressure tank attaches to the reservoir and pumps new fluid in. Since it's presurized by the hand pump (and stays pressurized), you just open the bleed valves on the brakes and let it drain. It makes it so much simpler. I've got one
Old Jul 16, 2003 | 05:03 PM
maxpesce's Avatar
Ex fd *****
I think the instructions ment to say it could be used to blead Hydraulic Clutch Systems also Not actual Transmissions
Old Jul 16, 2003 | 09:30 PM
banzaitoyota's Avatar
What Subscription?
I made my own version of that product. Works great on clutch hydraulics
Old Jul 17, 2003 | 04:17 PM
neo_omega's Avatar
***Moderator***
OH IC
I was wonder how the hell that work with tranny
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
SCinfidel
Sep 8, 2015 05:36 PM
Frisky Arab
Sep 4, 2015 06:17 PM
