Need info on a GSL-SE fuel pump **
Old Jul 13, 2003 | 03:09 PM
rhinor61's Avatar
Ok guys here is what I got. GSL-SE '85 CSP class- 115k on the odometer. Fresh fuel filter about 5 events ago.
AutoX today, ran 1st run the car ran fine, let it idle for a bit while it cooled down and then shut it off. 10 minutes later, no go. Had spark on both L & T, so I pop the right side storage box unhooked the fuel pump connector (still on grid) grab the test light. Turn the engine over and I had 12v to the pump.
Safe guess is that the pump is not pumping, since there was no noise coming from it while cranking the engine.
SO, do I go back with the factory fuel pump from Mazda Motorsports, or is there a better unit out there?
Let me know what you guys think?
John
Old Jul 13, 2003 | 05:22 PM
hornbm's Avatar
FD > FB > FC
well hearing the fuel pump is pretty difficult when your are cranking.
Personally I'd say make sure the engine isnt flooded, and if it isnt, I'd short the fuel pump out and see if it pumps, if it does you've got a problem with your circuit opening relay.
Old Jul 13, 2003 | 06:10 PM
RX7145's Avatar
-SE with Mods
If the pump is bad one of the best is the MSD 2225. 43GPH. From summit racing it is around $80.00
Here is a picture.
Old Jul 13, 2003 | 06:18 PM
rhinor61's Avatar
Very good information.
Pulled the spark plugs, all of them were dry.
SO, I broke out the shop manual to find the location to 'short circuit' the fuel pump circuit.
Its on the passenger side and has a 2 wire connector with a boot simular to that on the ignitor connector.
SO I 'short circuit' the fuel pump circuit, and sure enough the pump came on. TADA the pump was pumping fuel.
Next I went ahead and crank the engine over and the car started. DAMN IT wish I would have known about the 'jumper' location before today.
I pulled the jumper and the continued to run, it started everytime now with out the jumper, so what do I do know? Think the pump is bad... intermittent?
I am going run wiring to dash light from the fuel pump connector, and wiring to the 'short circuit' location to a dash switch for the time being.
thanks for your input, save me a lot of time.
John
Old Jul 13, 2003 | 07:08 PM
Consider yourself yucky.
I tried the same thing and i still got no fuel and no running engine so i have to buy a new one.
Old Jul 14, 2003 | 09:31 AM
rhinor61's Avatar
I wouldn't call it lucky, I still don't know why it didn't start while on the Autox Grid.
I would rather have it fail completely, than this intemittent start- won't start problem.
Like I said, I will do some wiring and add a switch to the jumper terminal, but I got a new pump coming as well.
John
Old Jul 14, 2003 | 01:25 PM
rhinor61's Avatar
Paul, it looks like the MSD 2225. 43GPH is what I will go with, cause Mazda Motorsports wants $250 for a new GSL-SE fuel pump.
DAMN....
Anything I need to buy extra parts of, because I don't think its going to be PLUG in and DRIVE solution?
Is there enough fuel line or anything else I need to get?
John
Old Jul 14, 2003 | 06:53 PM
RX7145's Avatar
-SE with Mods
Well I just thought of something. I'm using a 86' engine which has a pulsation dampener on the fuel rail. The -SE has one on the fuel pump. I don't know if it would make a difference without it. I don't think it would; but that might be somthing that you would have to buy after. The MSD pump will fit in the stock location. You will need about a 12"-16" 5/16 HP fuel line. To run from the pump to the filter. I can take a picture of my setup if you want.
Humm, as to the pulsation dampener thing; you might be able to use a fuel rail from a 86'-88'. I don't know it it will fit.
Here is the link for the fuel pump.
-Paul
Old Jul 14, 2003 | 09:07 PM
hornbm's Avatar
FD > FB > FC
is there any problem with using both?
Old Jul 15, 2003 | 06:05 AM
RX7145's Avatar
-SE with Mods
I never had any problems. But my stock pump died so I got the MSD pump.
Old Jul 15, 2003 | 10:20 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
There is a pulsation dampner on the fuel rail of the GSL-SE. There isn't one on the pump.
Old Jul 15, 2003 | 12:26 PM
RX7145's Avatar
-SE with Mods
Humm, Now that you mention it there is one one the fuel rail, Wow I feel dumb. But there is one on the pump also.
Old Jul 15, 2003 | 12:45 PM
abeomid's Avatar
Actually SE has a pulsation dampner on the fuel rail. SO you shouldn't have a problem.
-Paul
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
