Need help with WA State Emissions Failure!
Old Sep 12, 2001 | 11:02 PM
3Rotor's Avatar
Unhappy Need help with WA State Emissions Failure!
I have a friend with a 1991 NA RX-7 that he has been dinking with. He wants to sell it and move on to other projects. He just took it to be smogged. It passed all but the CO test at idle - it is running at about 60% higher than the allowable limit. It does have the orignial pre-cat and main cat (with 114K miles), and a Magna flow exhaust. He does have what appears to be an after market main cat (only this piece, though) that he got with the car. Any suggestions?
Old Sep 13, 2001 | 07:32 AM
Six Rotors's Avatar
If you have access to a Haynes manual or factory manual,perform the checks described for the secondary air injection system.The likely problems could be the temperature switch(bottom drivers side of radiator)look for broken wire or corrosion,or a malfuntion in the ACV.
Old Sep 13, 2001 | 07:45 AM
3Rotor's Avatar
Would replacing the stock pre-cat and main cat with the single after market main cat help - assuming this other main cat is newer?
Old Sep 13, 2001 | 03:53 PM
Six Rotors's Avatar
It might-all depends on relative condition etc.I use Catco and they work well for 40-50kmiles.
Old Sep 14, 2001 | 08:49 PM
3Rotor's Avatar
Talking
Thanks 6 Rotors. I passed today!
ls1swap
Jun 3, 2024 03:25 PM
