racing beat header? confused...
Old Jul 11, 2003 | 11:27 AM
Sk8r_dude's Avatar
Zoom - Zoom...
i was looking at the racing beat site, ans i noticed this:
An Air Control and Check Valve Cover Plate is required when using this header with a stock intake system.
Whats that? im confused...can you guys help?
Old Jul 11, 2003 | 11:55 AM
Sk8r_dude's Avatar
Zoom - Zoom...
anyone?
Old Jul 11, 2003 | 12:11 PM
MikeLMR's Avatar
'Last Minute' Rallying
THe air control valve and check valve are all parts of the emmisions gear associated with the air pump and exhaust converters ... the header removes the exhaust converter and so the air pump is no longer needed and neither are the valves so they are removed and blanked off with the plates you listed
Old Jul 11, 2003 | 12:48 PM
Sk8r_dude's Avatar
Zoom - Zoom...
hmmm....thanks, i need to think about this...my air pump is off rite now, but i was going to put it back on, cause i have one more emissions check left...im not sure what i should do. does the header replace all the cats? i think i should leave at least one, and put a resinator on too. if i left one cat would i still use the air pump and valves?
Old Jul 11, 2003 | 01:02 PM
Chemical's Avatar
Yes, if you left the main cat in there you would need the Air pump and ACV still
Old Jul 11, 2003 | 01:23 PM
Sk8r_dude's Avatar
Zoom - Zoom...
awesome, thanks guys.
Old Jul 11, 2003 | 02:10 PM
poweRX-7's Avatar
but don't try this with a header installed
Old Jul 11, 2003 | 11:18 PM
Why would there be a problem with using the main cat in conjunction with the header, as long as it was a 2 into 1 design?
