engine rebuild assist piece?
Old Jul 10, 2003 | 08:07 PM
SortedDub's Avatar
I'm gathering some information before I reassemble my engine for the first time. I have read in the manual to place an "assist piece" under the apex seals before installing them. What is the function of this piece. My Mazda dealer isn't even aware that they exist.
Old Jul 10, 2003 | 08:28 PM
Rx7carl's Avatar
Airflow is my life
I dont think they make them anymore. It is un-necessary anyway, thats why I think. Its to help to corner of the apex sit correctly upon assembly IIRC. I just use a drop of crazy glue to hold it to the apex seal so it doesnt go "bing" and fly away when you fit the next housing on top of it. Believe me, thay have a tendancy to do that, sometimes into the motor so you dont know you did it. Watch them carefully when you put the housing down on top of it.
Old Jul 11, 2003 | 12:45 PM
I had them jumping all over the place...one time i had one jump from the rear rotor housing all the way down to the front end plate when assembling it. Imagine how that felt.
Old Jul 11, 2003 | 08:09 PM
SortedDub's Avatar
Thanks for the input. I will have to be careful.
Old Jul 11, 2003 | 10:18 PM
Sammymatik's Avatar
Oh god.... hearing that sound.... <<<ting>>>> <<<ting>>>
it's especialy bad as your just about to finish up the second housing!
<<<AAAARRRRGGGGHHHHHH>>>
Old Jul 12, 2003 | 02:22 AM
Jeff20B's Avatar
Lapping = Fapping
Indeed.
Old Jul 12, 2003 | 03:30 PM
Rx7carl's Avatar
Airflow is my life
Yea I forget who clued me in on that one (on the SA22C list), but thank you! Crazy glue saved the day many times since!
Old Sep 20, 2005 | 07:38 PM
autopaul's Avatar
lightened fb
heyy i dont know how old this thread is, sorry if its too old to bring up, but ****, i cant even tell you guys how frustrated i was this afternoon, trying to put my motor together, long story short is that i had to pull it all apart buy some crazy glue then scrape all the reassembley caulking off of my motor and new seals, i wish i had known, and yes that ting ting noise burns the devil inside me too,
just goes to show how much usefull information is on this site, wish i had done my researche before figureing the assist piece is not neccisary, well im out to go and buy some superglue,
Old Sep 21, 2005 | 01:15 PM
Jeff20B's Avatar
Lapping = Fapping
I assembled my first engine with wheel bearing grease (recommended by Lynn E. Hanover et al) yesterday afternoon. The engine went together smoothly and quickly without the horrid ting sounds.
Old Sep 21, 2005 | 01:22 PM
85TIIDEVIL's Avatar
ALLROTOR
I was told by a local engine builder to use Vaseline. Keeps things in place better, burns off quite well and helps as a sealing agent. I smear the stuff all over the surfaces of everything I am going to store to prevent rusting too.
Old Sep 21, 2005 | 01:38 PM
leknaw69's Avatar
Custom SE
ting, ting, tingitti...
I use Hylomar. each tube last enough for two engines. Craxy glue has help in more than one motor...
Old Sep 21, 2005 | 08:06 PM
Atomic Punk's Avatar
how well does the glue burn out?
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
