215mm vs 225mm????????
Old Jul 9, 2003 | 10:03 PM
R Lee's Avatar
Does anyone know how to tell if you have the 215 or 225 flywheel?? Im not sure what I have but I know what I had bought to replace it. I only want to do the clutch job 1 time a yr or 2.
Please give your feedback. I have a 82 with 4 port engine of dont know what yr..
Thanks!
Old Jul 10, 2003 | 12:32 AM
jutny's Avatar
SA all the Way!
82 should be the 215mm flywheel, they went to 225 in 83
Old Jul 10, 2003 | 12:43 AM
Siraniko's Avatar
RX for fun
BUT, there is a possibility that they still have the original 215 flywheel. You have to drop the tranny.
Old Jul 10, 2003 | 01:04 AM
rxtasy3's Avatar
Just measure it. The 215mm is 8.465"(roughly 8 1/2") and the 225mm is 8.858", just under 9"
Old Jul 10, 2003 | 06:26 AM
anthrax's Avatar
Heck Yes!
Is that diamater or radious?
My guess is radious but that is just a guess
Old Jul 10, 2003 | 06:40 AM
toxic_d's Avatar
radious
Old Jul 10, 2003 | 10:10 AM
R Lee's Avatar
So its the radius from the pilot bearing to the outter end?? Thanks for the input. Going out to measure now.....
Radius= 1/2 Diameter right?
Old Jul 10, 2003 | 10:12 AM
R Lee's Avatar
Trannys out....Aluminum flywheel and it had these small spacers between the pressure plate and flywheel..Dont know what they are for.
Old Jul 10, 2003 | 01:05 PM
anthrax's Avatar
Heck Yes!
Yes r=1/2d
Yes radius = 1/2 diameter
Old Jul 10, 2003 | 01:15 PM
anthrax's Avatar
Heck Yes!
Double Post
Stupit work server
Old Jul 10, 2003 | 11:59 PM
moremazda's Avatar
Gone Race'n
Randy,
The differance between the two is that the 225 flywheel is flat and the 215 is recessed. And these measurements are the diameter not the radius.
Ryan
Old Jul 11, 2003 | 12:04 AM
Siraniko's Avatar
RX for fun
Dont loose those spacers. Without it, the pressure plate will sit too far away from the t/o bearing and will cause the tranny not to disengage. if thats the 215mm, racing beat no longer make the replacement friction plates. 225 is still available.
risingsunroof82
Sep 9, 2015 08:06 PM
RX7 allnight
Sep 10, 2008 11:41 AM
Rusty Shackleford
Feb 26, 2007 02:35 AM
