How do you all mount your e-fans to your rad?
Old Jul 7, 2003 | 12:29 PM
Turbo Driver
I did a search but didn't find anything.
When mounting an e-fan, how do you go about attaching it to your rad? Obviously it woudn't normally mount right up, being from a different car, and my Taurus fan is no exception. Just wonder how you did it.
Old Jul 7, 2003 | 02:53 PM
RotaryMotorDisorter's Avatar
Im in the same boat as you, ide love to hear ideas. Im sick of looking at zip ties as mounts! It stays in place and cools it down enough though. LOL.
Old Jul 7, 2003 | 04:42 PM
ioTus's Avatar
'84 5-letter
Zip ties.
Old Jul 7, 2003 | 05:49 PM
Viperx7's Avatar
Go to the parts store and get a e-fan mounting kit. Costs about $5.
Old Jul 7, 2003 | 06:09 PM
ioTus's Avatar
'84 5-letter
NO! ZIP TIES!!!
they make e-fan mountin kits?
Mine is just on there temporarily right now. I'm going to be hooking up thermo for the dual speed and stuff soon.
I may have to look into these so-called "e-fan mounting kits" hehehe
Old Jul 7, 2003 | 08:58 PM
syklone's Avatar
now for sale
I second the Zip ties! Thats how mines attatched. It seems to work just fine.
Old Jul 8, 2003 | 01:54 AM
RotorMotorDriver's Avatar
Seven Is Coming
E-Fan mounting kit for me. Theyre just high tech zip ties basically, but they look neater IMO.
~T.J.
Old Jul 8, 2003 | 02:12 AM
Manolis_D's Avatar
Doubled up zip-ties baby
Old Jul 8, 2003 | 01:25 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Flat weldable steel bent and drilled to mount to the radiator mounting points Or just use the easy solution wire tires
Old Jul 8, 2003 | 02:15 PM
i thought that you needed to keep the original fan shroud in order to apply the electric fan..thats what other members on the board had told me over and over again,
Old Jul 8, 2003 | 02:23 PM
1984se's Avatar
Ryan
what fan fits again? I got one from a like 90 something taurus V-6 but didnt fit at all the motor in back of the fan was huge. which one is it??
Old Jul 8, 2003 | 03:24 PM
poweRX-7's Avatar
i am about to mount mine, hopefully today. it is out of a 91 tempo.
peccas, i also wondered why people would say to use the stock shroud. i found that most people use the electric fan shroud (as it usually comes built in to it) but i guess that there are e-fans out there without them?!
i am going zipties all the way!
jeff
Old Jul 8, 2003 | 04:38 PM
RXTbone's Avatar
This guy used eye bolts...
http://rx7.voodoobox.net/howto/efan/efan.html
Old Jul 8, 2003 | 04:55 PM
Matty's first 1st Gen's Avatar
Boosted 7
ok, just my two cents but, if your stock fan is having clutch problems i would change it, but its everything is fine, i left mine the way it is. because first the power gains are completely un noticable, the only real gain is less noise. second the ammount of current those things suck up are pretty good, especially if you have a stereo and and driving with fog lights and head lights. lastly I would definatly use the stock shroud, because it allows air to flow through the rad much better if you notice of the e-fan's shroud there are flat plateaus on the cornors and on the right edge. When using the e-fan shourd my coolant temperature was much higher than using the stock shroud, especially on the hiway.
Just my two cents, I threw my e-fan in the garbage, and now my coolant is back to being very cool
Old Jul 8, 2003 | 05:04 PM
1st to 3rd's Avatar
Mounting a Taurus fan cleanly:
Use the little mounting tabs for the stock shroud with the bolts removed (red arrow). Line up the e-fan shroud, mark were the tabs are and cut two small slots. The e-fan lip (green arrow) will slide behind and the tabs should fit tightly in teh slots you cut. That side is secure (and tight to the rad for good air flow). One the otherside, drill two holes in the rad bracket. This is much much easier with the rad out, but can be done with it in using a 90º drill. Make sure to put a piece of metal between the rad core and bracket... don't blame me if you drill into your rad!! Secure that side with two short self-tapping sheet metal screws.
It's more work, but looks a lot cleaner then zip ties.
Who has been saying to use the stock shroud? There are aftermarket fans that come without their own and you have the stocker.
msilvia
15
Sep 11, 2015 12:13 PM
freq
Sep 7, 2015 04:35 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
