Have you done the hose job?
Old Sep 11, 2001 | 03:56 PM
efiniracing's Avatar
Exclamation Have you done the hose job?
If so I need your help. I can't find where the hoses go for the solinoid (A ) in the vacuum hose diagram. It's for the pressure control but I see no nipple for the front nor the back hose. Is it in a non visible area? It's for the solinoid that is closest to the firewall. Need help must finish by Friday!
Old Sep 11, 2001 | 05:02 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
I just finished mine last weekend. I'm not quite sure about what hose you are talking about but check out this diagram http://www.robrobinette.com/cgi-bin/i/images/hoses.gif
The owners manual also has the same diagram but it is a little bit clearer. Hope this helps
Old Sep 11, 2001 | 06:20 PM
Thats the same diagram I'm using. But I still can't find it. If you follow the hoses from solinoid A, one goes to the press control but the other one just kinda dissapears. So I'm thinking that the nipple for that hose is not visible but I'm feeling my way around and can't find it. Damn I promised my sponsor that I would be at Nopi, and I still gotta put my radiator in.
Old Sep 12, 2001 | 09:22 AM
C'mon guys someone on the forum should know. Should I repost a tread for FD gurus only? Are there ant FD gurus on this forum?
Old Sep 12, 2001 | 03:32 PM
yomamasmama's Avatar
there is a nipple at the rear of the manifold, you may have to remove metal intake pipe to 2ndary turbo to see it,
Old Sep 12, 2001 | 09:42 PM
What about the 2nd hose from that same solinoid? I can't find where that goes. Thanks in advance!
Old Sep 13, 2001 | 06:21 PM
bump
Old Sep 13, 2001 | 06:58 PM
Rotary93's Avatar
Retired RX7 mechanic
I did the vac hose replacement myself 2K miles before my car went to KD Rotary for a motor swap...When I got it back, I noticed a intake leak between the upper and lower manifold....I replaced the gasket....When It was off I noticed that Dave at KD had taken the vac hose off the solinoid and remaped it too a different area under the ACV...I called him and asked him if this was correct...He said it was remapped to a different area because of the simpicity....It was ok...Runs great
Old Sep 13, 2001 | 08:50 PM
Maybe thats what Pettit did w/ mine? Maybe thats why I can't seem to match up all the hoses w. a nipple. I seem to be having One extra nipple on the solinoid (other than the ones for auto.) and one nipple that I can't find on the lower manifold. man this sucks!
Old Sep 13, 2001 | 10:04 PM
whitekingsnake's Avatar
Hey Efiniracing,
I live just outside Alpharetta amd have done my own. If you want i can look at it with you tommorrow. I get home around 1:30 on Fridays.
Scott
Old Sep 14, 2001 | 09:21 AM
911 911 911 Whitesnake I have sent you a PM.
Old Sep 14, 2001 | 10:46 AM
FastX7's Avatar
To do my own hose job, what length's (approx) and sizes will I need to do it? I've been wanting to get it done since I've had the car...
Old Sep 14, 2001 | 06:06 PM
Mikey's Avatar
i got my kit from hose techniques...right now i am almost done with the job and the hose fits and looks great...here is the link to the kits
http://cyber.virtualrep.com/hosetech...c%20SVH%20Kits
