Difference between gls-se and second gen 13B
Old Jul 5, 2003 | 02:33 PM
Sk8r_dude's Avatar
Zoom - Zoom...
whats the difference between the gls-se 13B and the 86 13B? i was rwading the specs and the gls-se has 135HP and the 86 has 145HP where does the extra 10 HP come from?
Old Jul 5, 2003 | 02:44 PM
Manntis's Avatar
add to cart
lighter rotors and a redesigned Dynamic Effect Intake.
Whereas the DEI on the GSL-SE is essentially a box that pulses the intake waves fro port to port, creating a sort of pseudo supercharge, the DEI on the 2nd gen 13B has a smoother, more rounded inner chamber that fills in the dead spots and makes for better pulse tuning.
There may be other differences as well.
Old Jul 5, 2003 | 03:02 PM
hornbm's Avatar
FD > FB > FC
the FC 13b has bigger ports too.
Old Jul 5, 2003 | 04:02 PM
Sk8r_dude's Avatar
Zoom - Zoom...
ah...i was thinking about a hybrid cause i bought a gls-se but i dont think its worth it. ill work with the 135 for now and find other ways to squeeze the HP out.
Old Jul 5, 2003 | 04:29 PM
Manntis's Avatar
add to cart
RB exhaust will help
Old Jul 5, 2003 | 04:37 PM
rx-7 crazy's Avatar
ignition system was up graded lead coil in a 2ng gen fires both lead plugs
Old Jul 5, 2003 | 05:52 PM
Jeff20B's Avatar
Lapping = Fapping
Another big difference was the water seals. Mazda moved them from the rotor housings to the side plates. Kinda of a dumb move if you ask me.
The Renesis has them back in the rotor housings.
Old Jul 5, 2003 | 06:12 PM
RacerX7fb's Avatar
paradox
the S4 FC has bigger intake ports, throttle body and AFM
Old Jul 5, 2003 | 08:14 PM
Turbo Driver
You still have the faster car stock. Don't worry about it.
As far as the AFM, I was throwing around the idea, and I'm not sure if it'd work, but are they interchangable between the SE and S4? The fact that the SE has the square entrance make using an adapter for a cai pretty much nonexistant. I was thinking of getting an S4 AFM, so I could just use an intake kit for one of those cars....
Old Jul 5, 2003 | 08:21 PM
rotarygod's Avatar
Rotors still spinning
The GSL-SE afm is NOT compatible with the 2nd gens. Any of them. They will physically plug in to each others plugs but the internal circuitry is different. Also the 2nd gens have 2 wires that are somewhere between 5 and 8 volts going into the afm where the GSL-SE has only 12 volts running into it. There is a way to actually modify the curcuitry but the values on the swingarm of the afms are much different and it still won't work properly.
You can adapt the intake manifolds from the 2nd gen to work. It takes a little bit of effort but can easily be done in an afternoon. Primary port runners are different sizes and need to be adapted. This is easy. You still need to use the GSL-SE afm though for the above reasons.
Old Jul 6, 2003 | 11:22 AM
The_7's Avatar
Registered Piston Eater
what about the FD engines? excluding the twin turbos, what are the advantages over the fc 13b?
Old Jul 6, 2003 | 11:55 AM
JIMMY54's Avatar
GSL-SE PRO
I think all fd's are twin turbo.
Also the big difference is the apex seals in a -SE 13b are 3mm where as the 86 onward are 2mm.
Big difference in engine life.
Aren't -SE's quicker than n/a second gens anyway?
Old Jul 6, 2003 | 03:33 PM
Lookieme's Avatar
Cornbread
What he meant was: What are the advantages of the FD motor (if you leave off the turbos).
Old Jul 6, 2003 | 04:53 PM
The_7's Avatar
yea
Old Jul 6, 2003 | 04:55 PM
Pittdp's Avatar
they needed 10 more hp to make up for the body weight.
Old Jul 6, 2003 | 05:18 PM
diabolical1's Avatar
dude, really, i'm not trying to be a tool ... but are you changing the question everytime someone gives you an answer? maybe it's me ...
anyway ... what is you plan/goal for the car?
the SE's motor is VERY different from the Gen II motors (S4 and S5) which are A LITTLE different from the Gen III motors - a few pieces aside.
here's something that helps with some of the 13B-REW stuff, but it's not clear what you want or what you want to try ...
i seriously doubt you'll be in a situation where the differences between a 13B-T and 13B-REW are going to matter - and they are slight. in fact, the S5 13B-T is VERY similar to the REW (port size, mounting points and ancillaries aside) - so what exactly do you want to know?
Old Jul 6, 2003 | 06:03 PM
The_7's Avatar
umm i wasnt the one who posted the original question i just expaned on the one he already asked cause i was curious
Old Jul 6, 2003 | 06:08 PM
OOOPS!
my bad ... my apologies to both you and sk8r dude
the diabolical one = too much time in front of this monitor, what else can i say?
EDIT: to All: just disregard my last post
Old Jul 6, 2003 | 06:24 PM
The_7's Avatar
i dunno about sk8r dude but i think when im ready to do my swap (which wont be for a long time) im gonna go with the 13B-REW and im going to give it twin TO4E turbochargers, and an aggressive periphial porting...as for now all i can afford is to keep my 12A and give it mild streetport
Old Jul 6, 2003 | 06:26 PM
The_7's Avatar
lol no harm done d1
Josh83rx7
Sep 2, 2015 05:57 PM
Inspector71
Aug 26, 2015 12:06 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
