Diagnosing my A/C...
Old Jul 4, 2003 | 07:46 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
Question Diagnosing my A/C...
Well... I finally got some time this weekend and one of my goals is to fix my A/C. The clutch doesn't engage when I flip the switch inside. I took the green wire and connected it to the positive--the clutch engages and it turns just fine. I tried this with the car on but the air did not get cooler (with the A/C switches on and set to max inside the car). Next thing I did was check level of freon--just fine--no bubbles and I can see the freon moving along. So, I'm guessing at this point I have a bad relay... but why didn't it get cooler when I manually engaged the clutch? And where can I get a relay to replace the bad one?
Thanks
FS
Old Jul 4, 2003 | 10:27 PM
FuLLsMoKe's Avatar
no ideas?
Old Jul 4, 2003 | 10:38 PM
jerij's Avatar
A/C's are a hassle. Your compressor could still be malfunctioning, your condensor could be blocked, your orifice tube/expansion valve malfunctioning, or the door to your heater/AC blower isn't pulling air through your evaporator. A/C diagnosticians earn their money.
Check it out.
http://www.autosite.com/garage/subsy...rc01.asp#Chap1
jerij
Old Jul 4, 2003 | 11:16 PM
YANK it out, MUCHHH more room in there for other goodies. I ganked mine last week, i don't miss it for a sec, and it gets hot up here. weighed exactly 42lbs too
Old Jul 4, 2003 | 11:55 PM
Spieder's Avatar
Ok, here's the scoop on your A/C. I just replaced mine last year. If the clutch isn't engaging when you turn it on, it's because you have no pressure in the A/C system. The A/C has a pressure gauge, if the freon leaks out, it won't engage the pump.
The reason for this, is that the freon contains the oil lubircant. When the freon leaks out so does the oil. The compressor won't engage any more so it doesn't burn up.
So, now you know you have no charge. You need to take your care down and have it checked for leaks. You have a 90% chance that your compressor is bad.
If it is, you'll nbeed to replace it. They are about 200$. Then you'll want to go to R134a (so much cheaper). With the fitting adaptors, the labor to evacuate and charge the system and a new condensor, it was about $400.00 total. Don't forget you'll need to replace the seals in the compressor and the condensor with new "green" seals. If you don't the R134a will eat them out and you'll be screwed.
Old Jul 5, 2003 | 12:26 AM
jerij's Avatar
Just about everything you didn't want to hear, right?
Like I said, they are a hassle. (But both mine work in my 2 GSLSE's and I AM OH SOOOO HAPPY!)
jerij
djSL
The Bad & Fugly Businesses
24
Sep 21, 2017 03:09 AM
R.O.D
34
Jan 6, 2016 12:09 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
invinciblejets
Sep 13, 2015 08:22 AM
