Help!!!.. My exhaust is too loud..
Old Jul 3, 2003 | 11:20 AM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
I recently put on a midpipe.. and now, my car is too loud and gets too much attention.. I'm afraid that cops will hear it and come after me.. At my age, thats last thing I want..
I would hate to get a different type of midpipe.. what would you guys think about wrapping it with heat wrap? Would this help the sound??? I would think it will help a little.. Since its all steel from Down to cat (N1 Dual). its like hitting a bare metal.. i would think that wrap will act like dampener... I was going to do the wrap thing anyhow to contain the heat..
Please post your thoughts or experience with this.. as all this is just speculation in my part..
thank you!
PHIL
Old Jul 3, 2003 | 11:21 AM
Herblenny's Avatar
This is what I was going to use to wrap it:
Originally posted by 93BlackFD
9379K93 - High-Temperature Pipe And Tube Wrap, 3" Wide X 1/2" Thick X 12' Long
7760K121 - Sized-To-Fit Stainless Steel Banding, 1/2" Wide, .015" Thick, 3-1/2" Max Od, Blue
Old Jul 3, 2003 | 11:23 AM
Herblenny's Avatar
Its from "Mcmaster.com"..
Price is reasonable.. about 20 for 12 ft.
I was going to wrap the down, mid, and portion of my cat..
Old Jul 3, 2003 | 11:25 AM
ptrhahn's Avatar
Might help some, but for real change you will likely need to either:
1. Switch to a quieter carback, like an RB dual.
2. Have a muffler welded into your existing MP (i forget what type everyone uses)
3. Buy a resonated MP.
4. 1. and either 2 or 3.
Old Jul 3, 2003 | 11:26 AM
Herblenny's Avatar
Description of the wrap..
"High-Temperature Pipe and Tube Wrap
?_Temperature Range: -50° to +2300° F
?_Heat Flow Rate: 0.25 Btu/hr. x in./sq. ft. @ 75° F
_____This durable wrap not only withstands extreme heat, it also has excellent sound absorption and resists tears. Made of white alumina-silica based ceramic fibers with an aluminum jacket, it's unaffected by hydrocarbons and water and resists most chemicals. Use this UV-resistant material indoors and out. Install with banding (see 7760K on this page). "
Old Jul 3, 2003 | 11:30 AM
kyle@insight's Avatar
Dont like it? I dont care
Might want to try a resonated midpipe, tho I doubt you want to since you just bought a midpipe and that's what made yours louder
Just figured I'd throw that out there.
Snook's Avatar
Tony Stewart Killer.
or you could put the silencers in. Do you have them?
I had silencers made for my n1 and it quiets it down tremendously but also makes the car much slower when they are in.
Old Jul 3, 2003 | 11:36 AM
Tom93R1's Avatar
gross polluter
Haha, you havean N1 dual and dont want to attract attention to yourself with the sound? If you want to be quiet sell that and get a RB dual tip. You will probably lose 1-2 HP but the sound will be much much less attention grabbing. Wrapping the mid pipe wont help, a resonated mid-pipe will help just a little, an in-line muffler would be the best bet if you dont want to get rid of the N1.
matty's Avatar
buy a resonated mp with the rb dual...it isnt so bad...definately liveable
Old Jul 3, 2003 | 11:55 AM
apneablue's Avatar
I just bought a resonated MP (not yet installed) and have a RB dual tip...Will be interesting to see what kinda db come out of it.
Old Jul 3, 2003 | 12:32 PM
the_saint's Avatar
Weld in a Borla XR-1 Sportsman silencer/muffler.
16 inch, oval, 3 inch inlet/outlet.
Available from Summit Racing.
Works great.
Cuts down drone when cruising, idle is loud, but not stupid loud.
WOT is still very very loud.
Mine was welded in at about a 15 degree angle to allow proper clearance. Depending on your MP you might be able to get it welded in flat, but that is a moot point.
Just make sure it doesn't hit anything underneath the car/chassis/frame/tunnel etc etc.
thesaint
Old Jul 3, 2003 | 12:35 PM
Shinobi-X's Avatar
Sensory Experience
Please let us know, as I will be running that setup as well.
To the person with the sound problem, try the RB dual tip- the amount of power you will loose, won't be much...just ask Vosko...
Old Jul 3, 2003 | 12:50 PM
fastcarfreak's Avatar
3rd motors a charm I hope
how much louder can puting a midpipe on there over a stock cat. I have an appointment with KDR to install a midpipe and do some Dyno tuning. you guys are starting to scare me. Can you guys give me an estimated decipuls increase?
Old Jul 3, 2003 | 12:59 PM
Nameless's Avatar
If you dont want to get a resonated midpipe, try the carchemistry inserts. They worked pretty well on a project I had, we used a decibel meter from radio shack and it lowered it by 5 or 6 dBs, from what I remember. It was on a ae86.
If you want one I have one in the garage somewhere, sell it for cheap. Was going to use on my car, but I dont think there is a need to anymore.
Old Jul 3, 2003 | 01:22 PM
rynberg's Avatar
It's "decibels".
From my experience with friend's FDs, a midpipe is atleast 6-8 dB louder at idle with the same cat-back. At WOT, it is at least 10 dB louder (subjectively, twice as loud or more).
Old Jul 3, 2003 | 01:39 PM
Brentis's Avatar
how does RB dual compare to pfs? My pfs is pretty loud with the high flow cat + I'm not a big fan of the way the tip looks.
Old Jul 3, 2003 | 01:42 PM
apneablue's Avatar
I don't know about the PFS but the RB kicks ***...You know why? Because I have it!!!
Old Jul 3, 2003 | 01:58 PM
ptrhahn's Avatar
PFS is louder than RB. A local guy had a PFS w/ highflow and Apex Single-T... commanded too much attention from the cops. He switched to a RB dual... its not as loud anymore.
Old Jul 3, 2003 | 02:01 PM
Herblenny's Avatar
A good friend "SPOautos" have resonated Mid and RB dual.. maybe its pettit.. I don't know.. but its not that loud at all..
Man, I didn't know mid pipe will make it this loud.. I might just go head and get some N1 silencers.. and use it during just in town driving....
I've also talked to the ATL distributor of the wrap and they told me it will reduce the sound some.. but not back to where it was.. So, I'm going to order 36ft of this wrap and wrap it.. Its going to be about 80.00 job.. but at least I will contain the heat..
Old Jul 3, 2003 | 02:04 PM
Herblenny's Avatar
Oh.. I guess I could sell the MP and get the resonated one.. but do they really cut down the noise to a noticable level?? I think my catback isn't the ideal.. but I like the look of it.. and with my stock cat.. it sounded great... but just too loud now....
Old Jul 3, 2003 | 02:11 PM
apneablue's Avatar
If you all are willing to wait a few weeks I can post an MP3 with the exhaust at idle and a coule of revs in there...actually it may be longer since i am moving over the next couple of weeks.
Old Jul 3, 2003 | 02:54 PM
Icemastr's Avatar
All Motor
I have a pettit resonated midpipe which uses a Magnaflow oval muffler, and an Apex GT Spec exhaust, its loud enough that my neighbore cusses at me when I warm my car up, and if i cruise at over 2900rpm on the freeway you can't hear someone talking very well, and its almost ridiculously loud when you get on it, so I don't know what to say...
Old Jul 3, 2003 | 04:12 PM
NeoTuri's Avatar
The shy megalomaniac
I have a similiar setup and it's obnoxiously loud on the road. I just ordered the silencer for the Apex catback a few days ago.
Old Jul 3, 2003 | 05:20 PM
adam c's Avatar
Cheap Bastard
Sounds like a waste of $80. The mid pipe isn't located in the engine compartment, so you aren't reducing engine heat. The wrap will go around the outside of the mid pipe, so it will have ZERO effect on the noise level out the back. In addition, if you decide to weld in a resonator later, you will just have to remove it. I don't know if it is the type you can reinstall.
I suggest you spend the money to have a muffler welded into the midpipe. The wrap is useless.
Old Jul 3, 2003 | 05:39 PM
Herblenny's Avatar
Well, i was going to wrap down, mid and part of catback..
Do you think its better for me to not wrap it and go with N1 silencer?? or just sell the damn thing and go with Pettit resonated??
