How can I tell a real 93 R1??
Old Sep 10, 2001 | 05:16 PM
thatoneguy's Avatar
You can tell if they have a 2nd oil cooler and suede seats. Most people won't install a second oil cooler cause it's expensive and a bitch. R1s don't have Cruise control, sunroofs, and rear windshield wipers.
Old Sep 10, 2001 | 06:09 PM
Foz'sRX-7's Avatar
Red face
They have a cool front tower strut bar across the engine bay that has RX-7 stamped on it. No Cruise Control.
Old Sep 10, 2001 | 06:13 PM
Rotary93's Avatar
Retired RX7 mechanic
Thats a $850 stut bar from Mazda....Make sure you get it with the real R1...
Old Sep 10, 2001 | 06:26 PM
BlackR1's Avatar
Meesto Spakaro
R1's were only available in 93... the big bright red strut bar with rx7 on it is a good giveaway. (I've seen bright blue as well) R1's also have a front lip with brake ducting
Old Sep 10, 2001 | 06:48 PM
Want2race's Avatar
Bigger and better things
Put your hand in the second opening ... The one on the pass side of the nose...If you feel a radiator like thing.. Its an r1/2
Also look for these things:
Smaller diameter steering wheel(yes..ive seen this tested b4)
No cruise control
No rear wiper arm
Suade Seats
The strut tower brance in the front
Bigger antisway bars under the car
Thats about it....
Old Sep 10, 2001 | 06:57 PM
hawaii rx-7's Avatar
hey i know one thing no one has mentioned.
look on the dash around the guages. by the hood lever, it hould have R1 embossed. i'm not too sure how many have this or even noticed, but it's another thing to look for.
Old Sep 10, 2001 | 08:41 PM
SleepR1's Avatar
R1/R2
The R1/R2 seats are made of unique cloth interior and came only in black. Mazda did not use suede leather because cow skins weighs more than the cloth!
NO halgen fog lamps either.
There are subtle differences between R1s (93 only) and R2s (94/95). The rear sway bar diameter is larger in the R1 than in the R2. The shocks are stiffer in the R1 vs the R2.
93 R1s came in Red, Yellow, and Black only.
Front air damn and rear spoiler was standard on the R models.
Old Sep 10, 2001 | 09:14 PM
FDeez's Avatar
Someone can correct me if I'm wrong, but for 93s, if you look at the tach, there are line markings for about every 100 RPMs, while the other years, it's at every 500 RPMs or so. Unless the extra lines exist in 94s as well. I've pretty much only have gotten close looks at 93s and 95s. Oh, interior dash panels on 94+ models are a bit textured as opposed to smooth in the 93. And to my knowledge if it's yellow, it's an R1 (unless it's an aftermarket color).
Old Sep 10, 2001 | 10:16 PM
evot23's Avatar
Classy
CYM was only available for the 93 R1. R2 (94)has everything the R1 has except with a softer ride.
Old Sep 10, 2001 | 10:26 PM
JoeD's Avatar
actually, all 93 FDs had the small increments in the tach. then for 94-95, they changed the tach to an increment every 500 RPM. it doesnt matter what model the car was.
Old Sep 11, 2001 | 05:09 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
What models came with rear windshield wipers?
Old Sep 11, 2001 | 06:05 PM
evot23's Avatar
Classy
All touring/PEP models
Old Sep 11, 2001 | 11:00 PM
Nathan Kwok's Avatar
If you do up a base model right, it would be very hard to tell from a real R1 without doing a VIN check. But then, unless you're in it for the collector's value, it wouldn't be effectively any different anyway. I think the easiest giveaway is the rear wiper, since no one goes through the trouble to eliminate it, but there are seat swaps, and spoiler, oil cooler, and brace addons. Of course, base models don't have the wiper.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
Robrods64
Oct 2, 2015 07:56 PM
