kk
Old Sep 10, 2001 | 04:47 PM
artguy's Avatar
WTB** Very Low Miles 94-95
kk
its the motor...dammit!!
argh...compression test this morning and ran a 7,3,2 on the back rotor...sob.
Im rebuilding with ceramic seals...fark this 15lb max crap...I want to run 13-15 lbs and not worry anymore
thanks guys
jason
Old Sep 10, 2001 | 05:34 PM
Toadman's Avatar
Nomad Mod
Lemme know if you want to go with those ceramics 3mm's. Good to 24psi of boost and damn near bulletproof from detonation.
Old Sep 10, 2001 | 06:16 PM
BlackR1's Avatar
Meesto Spakaro
actually, detonation will happen no matter what kind of seals you are running. It all depends on your fuel tuning/timing and what grade of gas you're running. I wouldnt run more than 14 psi on the stock turbos with pump gas. I think 15 is the absolute max? Anything more than that and you'll need racing fuel.
Once I get the dyno tune my girl, im keeping her at 12-13 at the most.... that is... before going single turbo :p no more shoddy sequentials to worry about. I've heard A'pexi's IHI RX6 ballbearing single turbo has hardly any noticeable lag and excellent power throught the rev range.... just a thought
Anyhow...my condolences for your 7... hopefully when it's all finished it'll be badder than ever
