engine won't turn off
Old Jun 29, 2003 | 06:02 PM
rx7chick's Avatar
The ignition on my '85 stock gsl won't turn the engine off when I turn the key off.
Old Jun 30, 2003 | 12:45 AM
Icemark's Avatar
off to first gen
Old Jun 30, 2003 | 12:52 AM
it might be your ignition itself or maybe your wiring needs to checked , sorry couldnt be of more help. good luck hun and happy rotors
Old Jun 30, 2003 | 01:46 AM
vic'srx-7's Avatar
I've had that happen. It is usually a worn out ignition switch, I would check to see how much a new one is or just grab a used one. You could take a look for yourself easily enough.
Just take the cover off of the steering collum(?) and insert the key and turn it. You should be able to tell.
Vic
Old Jun 30, 2003 | 09:16 AM
rx7chick's Avatar
engine won't turn off.
I've replaced the ignition wiring and in the process checked the mechanical part of it and it seemed OK. I'm baffled.
Old Jun 30, 2003 | 09:50 AM
Pele's Avatar
Right near Malloy
Exclamation
A chick that works on cars! Mmmmm
I'll help you with that... Over dinner... Umm... or something...
Umm ahem...
Yeah.. Perhaps the switch is damaged internally. I have several switches from other cars that do that... Either they stay cranking the engine after you release the key, or they kill the ignition after you're done cranking, or they exhibit the same problem you're having...
Incidentally, I saved them, cut up the harness and installed toggle switches... Now I use them at impound car auctions at the rare times I go and bid on something...
Anywhozer, you might wanna get a hold of a wiring diagram and a multimeter...
Jun 26, 2016 10:21 AM
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
