Suspension/spring rate questions
Old Jun 29, 2003 | 06:02 AM
O 16581 72452 5's Avatar
The infamous number guy!
I'm looking to buy this "coil-over" kit http://www.ground-control.com/gcrx7cat.htm see on this page, how are these installed? i'm pretty new to suspension work... never messed with it much until now...i'm also wanting the stiffest springs they have... the 700lbs/in, but would this cause damage to my stock car, i don't mind it being stiff as hell. the roads i travel are generally completely smooth. i already have fairly stiff rear springs in my car (not sure the spring rate they're aftermarket and came from the front of a hyundai and fit almost perfect) i got them for free.
Old Jun 29, 2003 | 10:03 AM
Aico's Avatar
700lbs/in seems VERY stiff to me. Like in too stiff.
Old Jun 29, 2003 | 11:20 AM
rx7gslse's Avatar
EX Pres of DFW Drunks
700?
Yeah, that's pointless on a car this light. You might as well put a steel block on ther einstead of a spring...
For the most part people run 300 or 350 in the front and 175 or 200 in the rear..
I'm running the 350's up front and that's about at stiff as you coudl possibly want for street driving.
A few guys who have dedicated track cars run more like 500f/350-400r but again, we're talking bridgeported modified class cars here on 16x10 hoosiers.
Ask Ground control, they knw theire **** and will set you straight for you application.
Old Jun 29, 2003 | 11:26 AM
rx7gslse's Avatar
700?
Old Jun 29, 2003 | 03:00 PM
700 would just be fun though... like driving a big go-kart.
Old Jun 29, 2003 | 03:37 PM
851stgen12a's Avatar
Off riding sportbikes!
Hmmmmm , I have driven an SE with 450LB springs up front.
I am not joking when I say that my back hurt for the rest of the week because of how stiff it was.
The car is so light there would be no performance advantage to the car.
About the only thing it will do is make you look really dumb, as you drive around the streets with your car bouncing from every little stone and bump on tyhe roan.
Old Jun 29, 2003 | 03:48 PM
It'd look like a little indycar...okay maybe i should try to get 450-500 at the most? i guess i just need to talk to the guys at that site and see what they say. i still want to know how these coil-overs are installed though.
Old Jun 29, 2003 | 04:50 PM
rhinor61's Avatar
Call Ground-control and talk to Jay, and tell him what you want to do. Don't be affended if he drops the phone because he is laughing too hard.
450lb is about as stiff as the street will allow, before you start breaking your aluminum wheels and stress cracking other key areas.
Good luck with this project.
Old Jun 29, 2003 | 05:56 PM
rx7gslse's Avatar
here are some sots of my coil-over install on my old car to give you an idea of what you get..
http://www.digitex.net/ecarter/pics/dscn0001.jpg
http://www.digitex.net/ecarter/pics/dscn0002.jpg
http://www.digitex.net/ecarter/pics/dscn0003.jpg
http://www.digitex.net/ecarter/pics/dscn0004.jpg
http://www.digitex.net/ecarter/pics/dscn0005.jpg
http://www.digitex.net/ecarter/pics/dscn0006.jpg
http://www.digitex.net/ecarter/pics/dscn0007.jpg
http://www.digitex.net/ecarter/pics/dscn0008.jpg
http://www.digitex.net/ecarter/pics/dscn0009.jpg
Old Jun 29, 2003 | 07:20 PM
Heh, obviously suspension is a very new thing to me... i guess my question is like asking if i could run 40psi into my motor... obviously a very dumb question, thank you all for your help though, and for not telling me i'm a moron. i'll try to go for 450 in that case, i'll definately have to give him a call sometime, i have no money right now though... anyone want to buy a 1st gen eclipse turbo off of me for $170, anyone?
Old Jun 29, 2003 | 07:33 PM
wwilliam54's Avatar
it WILL run
350 front
200 back
Old Jun 29, 2003 | 07:34 PM
wwilliam54's Avatar
it WILL run
450 will probly break your air damn off
Old Jun 29, 2003 | 08:14 PM
...why would it break my airdam off?
Old Jun 29, 2003 | 08:17 PM
wwilliam54's Avatar
it WILL run
rattle rattle
bump bump
really hard suspentions break things
Old Jun 29, 2003 | 08:25 PM
That bumper is cracked and fucked up anyway, i don't mind. go-cart handling will be worth a few more breaks and cracks, i can't wait.
Old Jun 29, 2003 | 08:32 PM
Eville140's Avatar
Does that $90-$100 price include springs? Just wondering, becasue I was thinking of checking with afcoracing.com (they are down the street from me so it is convienent) and see if they would have stuff that would work. They have a few different coil over kits that look almost identicle to the one pictured on ground pounders wedsite, and a assortment of the 2.5" springs. Last time I added up everything it looked like both sides with springs would run a little less than $180. But if there price is with springs, might just not screw with it and irder the groundpounder setup.
Also does the coil oer kit give anymore clearance for larger wheels?
Later
Randy
Later
Randy
Old Jun 29, 2003 | 08:39 PM
Rx7carl's Avatar
Airflow is my life
450 is too hard for the street. Go softer. Eville yes the small dia front springs will give more clearance for bigger wheels. EIbahcs for the street/track come as a 171 in front. Let that be your guide.
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
blackball7
34
Sep 16, 2015 10:10 AM
Nosferatu
Sep 5, 2015 02:13 PM
