What's wrong with my 7!
Old Jun 27, 2003 | 11:49 PM
Rex79's Avatar
Reaction: .040
60': 2.418
I3: 11.071
E.T. : 17.304 @ 81MPH
Mods : Full RB Exhaust system, No air pump, K&N Filter
I've seen guys with the same setup run 16's no problem on the forum. What am I doing wrong? I launch at 4000RPM and shift at 7500RPM. I don't powershift(not too good for the tranny) but it doesn't take long for me to be in the next gear!
I wanna break the 16's!!!
Old Jun 27, 2003 | 11:59 PM
vipernicus42's Avatar
Rotoholic Moderookie
The weight of your cool sound system?
Hehe, just kidding with ya. I can't help ya here, but good luck getting it down to the 16s.
Jon
Old Jun 28, 2003 | 12:01 AM
Rex79's Avatar
lol yea the sound system definately doesn't help... I even took off my spare tire tonight to try to make it into the 16's:0
Old Jun 28, 2003 | 12:05 AM
jutny's Avatar
SA all the Way!
is the clutch grabbing, or slipping badly on the shifts, that can make a HUGE difference.
Old Jun 28, 2003 | 12:18 AM
Rex79's Avatar
nope the clutch seems okay....
Old Jun 28, 2003 | 12:41 AM
diabolical1's Avatar
the first things i would look toward would be:
clutch, engine and tranny mounts and get a good, complete tuneup
also ... you may try shifting at 7000 instead of 7500
Old Jun 28, 2003 | 09:55 AM
Your miles seem to be kind of low, it should be higher than that especially that you've got exhaust and intake.
On a 12a stock port with mikuni 40, header, stock muffler and launching around 3500rpm i've got:
60': 2.425
1/4: 16.006 @ 87.31
Old Jun 28, 2003 | 11:32 PM
Rex79's Avatar
yea I need a tuneup... I am running way too rich..
I feel like putting an 02 sensor on my header and wire it up to a A/F Ratio gauge in my dash... can I grab any O2 sensor off any car or it has to be a specific one? how do I install it? I could always go to the dyno and tune it on a wideband sensor but it's 170$/hour for the dyno so that hurts
Old Jun 29, 2003 | 10:49 AM
I assume you have a GSL-SE because you said that you've removed the air pump. On some cars it would actually make them run rich if you remove it, not sure about your car though.
Shouldn't you already have an O2 sensor if it's fuel injected? If so you might need to just replace it because a bad one will make it run richer also.
Old Jun 29, 2003 | 10:58 AM
inittab's Avatar
I read your email
Old Jun 29, 2003 | 11:06 AM
Sk8r_dude's Avatar
Zoom - Zoom...
look at where your rpms are as you pass throught the gate, you want to be at hight rmps, possibly eliminating one gear shift.
Old Jun 29, 2003 | 01:54 PM
Rex79's Avatar
lol don't worry about my RPM's... I'm at 7400RPM when I finish in third gear
I don't have a GSL-SE.. I have a 1979 12A
dona1326cosprings7
Oct 29, 2015 06:47 AM
pfsantos
Sep 30, 2015 01:29 PM
