Thermostat Replacement - Is it hard?
Old Jun 25, 2003 | 06:26 AM
anthrax's Avatar
Heck Yes!
Just that, I am looking to replace my thermostat in an attempt to solve my mild overheating problem.
Is this a hard do it your selfe project?
Can I complete it in a morning or afternoon?
Thanks for the input
anthrax
Old Jun 25, 2003 | 06:46 AM
wwilliam54's Avatar
it WILL run
2 bolts
1 gasket
make sure you put it in right
refill radiator
5 min job
edit
on the water pump, the top flange that the top hose goes into has 2 bolts, just undo those and the stat is right there, you dont have to unhook the hose from the flange
Old Jun 25, 2003 | 07:40 AM
inittab's Avatar
I read your email
5 min job IF the bolts aren't rusted and don't sheer off inside the water pump housing.
That's what happened to me and I had to drill it out and re-tap. The 5 min job ended up keeping my car off the road for a couple of days while I sorted things out.
--Bob
Old Jun 25, 2003 | 08:25 AM
pillage6's Avatar
With an Rx7, there is no 5 minute job, except for filling it with gas.
Old Jun 25, 2003 | 08:32 AM
anthrax's Avatar
Heck Yes!
Even that takes more then 5 min...
Thanks guys for your input
I will tackle this on the weekend.
...I hope
Old Jun 25, 2003 | 08:46 AM
anthrax's Avatar
Heck Yes!
double Post
Stupid work server
Old Jun 25, 2003 | 09:21 AM
85gsl2ndtimearound's Avatar
Just wndering how hard is the water pump.Sorry to jack your thread. planning on doing a compleat cooling system.
Old Jun 25, 2003 | 09:42 AM
anthrax's Avatar
Heck Yes!
Hey no problme here
Old Jun 25, 2003 | 09:54 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
I have done both jobs (several times) and apart from the fact that I wasted a lot of not so cheap coolant, it's an easy job. Of course, it can happen that bolts are rusted badly, in that case it becomes a real serious job To prevent that in the future, you can always use special grease on the bolts.
I also do no longer use gaskets, just fluid-gasket, blue loctite. Works perfect, and is easear to remove then those paper things that stick to the metal as were they glued. Blue loctite is ment for these things, so no worries.
Old Jun 25, 2003 | 10:08 AM
inittab's Avatar
I read your email
Originally posted by rotary emotions
.... Of course, it can happen that bolts are rusted badly, in that case it becomes a real serious job To prevent that in the future, you can always use special grease on the bolts.
Agreed! I put anti-seize compound on just about every bolt that I reinstall. This is important for any bolt that could possibly get in contact with water.
Old Jun 25, 2003 | 10:22 AM
anthrax's Avatar
Heck Yes!
Blue High Heat sealent, ok
Anti Seize, ok
Will Red High Heat Silicone Work?
Old Jun 25, 2003 | 12:11 PM
vipernicus42's Avatar
Rotoholic Moderookie
(sorry for the threadjack)
I used the red high heat silicone on my carb spacer/gasket.... anyone forsee any problems with that?
And I too am looking to replace the thermostat, any Canadians have a suggestion as to where to get a good one? I don't really like the Canadian tire thermostats, they have a reputation for being.. well.. crappy. Should I just buy one from Mazda?!
Jon
Old Jun 25, 2003 | 12:13 PM
pillage6's Avatar
Only use Mazda thermostats.
Old Jun 25, 2003 | 12:52 PM
anthrax's Avatar
Heck Yes!
Hey vipernicus42 I just picked up my Mazda Thermostat last night from the dealership. Their parts guy is great.
I ordered it friday, and it came in Monday
Its all Brass, very nice, and the concensous on the board is it sould only be the Mazda one because of the bypass valve that is operated by the thermostat.
I think it was like $20.00 CND if I remember right, I propably payed too much but thats ok because I am comfortable wiht what I bought
And I have no over head other then my car :P
Old Jun 25, 2003 | 02:31 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Use only Mazda Thermostats and make sure the "jiggle pin" is in the upward position..
Old Jun 25, 2003 | 02:55 PM
anthrax's Avatar
Heck Yes!
Ok so I get what the "jiggle Pin" is, but what is the upwards positon?
Can you please explain?
Thanks
Anthrax
monty11ez
Sep 7, 2015 11:40 PM
sYnth.
Aug 19, 2015 06:27 PM
GrossPolluter
Aug 16, 2015 09:50 AM
