13bt into 1985 gs??
Old Sep 9, 2001 | 07:01 PM
nitrouspeed2's Avatar
13bt into 1985 gs??
Hey guys will the 13bt engine fit into my rx7 without any mods, if so, what? Also, i saw that corksport sells these engines for $850 are they any good? Has anyone ever bought a engine from them?
If i decide to do this swap how much is it gonna cost me??
Old Sep 9, 2001 | 08:52 PM
Pele's Avatar
Right near Malloy
This comes up rather often...
AT THE LEAST, you'll need a GSL-SE oil pan and front cover, the TII ECU, oil cooler, fuel pump, and lines to the front. If the engine doesn't include it, You'll need the intake manifolds, down pipe, header, turbo, and intercooler. You'll need to either re-locate teh intercooler or get a hood scoop to work with it.
After you break a few 1st gen trannies, you'll wish you bought a TII transmission in the beginning. You'll have to fabricate mounts and a drive shaft for that. Then if you put out enough power, you'll break the differential. With the rear drums, you'll probably not be able to stop that kind of power anyway. So you'll wanna upgrade to a LSD rear end.
You're likely to spend close to $1500 if not more on drivetrain alone.
Old Sep 10, 2001 | 07:03 PM
bump
Old Sep 10, 2001 | 11:05 PM
Pele's Avatar
Right near Malloy
Bump what? I think people agree with me.
Oh yeah.add to the list of mandatory components, a 12A or GSL-SE front cover.
I believe either RX7Passion has done the swap successfully and can tell you what he used.
Old Sep 10, 2001 | 11:24 PM
NOTA V6's Avatar
Re: 13bt into 1985 gs??
This thread may come in handy for you at some point.
https://www.rx7club.com/vforums/show...threadid=19814
Good luck,
Old Sep 11, 2001 | 02:58 AM
rx7passion's Avatar
max7 and a few other contrbutors are making a page on what is needed since it is becoming a very popular subject. do a search in this section and you should find atleast 10 threads
NickNac113
13
Oct 1, 2015 09:25 PM
Hank
Oct 1, 2015 07:34 AM
WANKfactor
Sep 29, 2015 01:14 PM
