I need some pills!!!
Old Sep 9, 2001 | 06:12 PM
Blade7's Avatar
Talking I need some pills!!!
I heard of a pill that you can install to increase your boost. Have you heard of it? It's surpose to be simple and inexpensive to do.
I was wondering if you guys know whats up. Oh, who makes them and what is the cost , thanks !!
94' m2 stage 3
Old Sep 11, 2001 | 05:41 PM
nomadtw's Avatar
do you mean nitrous oxide? N2O?
Old Sep 15, 2001 | 11:40 AM
Blade7's Avatar
No, I don't mean the funny gas. I forgot were I have read it from, but it surpose increase boost up 1 psi at a time on each turbo.
It's actually a hardwar that you do something to the waste gate, I think. May be a actuator, clip or something.
thanks for the reply though.
peace.
donnie
Old Sep 17, 2001 | 01:59 PM
Boost pills
Yes, this can be easily done with very cheep holley carburator jets. You just take the old pills out of the vacume/pressure line going from the fitting on the compressor housing on the primary turbo to the wastegate control actuator. This line will have a small pill in it for restricting air flow. Take it out and replace with a smaller jet. The one problem you can experience with this is it slows the response of the wastegate, so be very careful. Also if you donot have a fuel computer and/or an intercooler then I highly discourage this. Be careful not to confuse the pre-control with the wastegate. Also chnge sizes slowly. This can be the difference between 1-2 psi of extra boost and a blown motor. If you donot know much about the control system don't **** with it. It will bite you!!!! More information can be learned on Rob Robinett's archives. I think the website is www.rx7turboturbo.com or something like that. Again I suggest against this without you having more knowledge of the system or you will blow you engine!!!
RX7s
Apr 2, 2002 01:45 AM
Toadman
Apr 1, 2002 04:22 PM
Wankel7
Mar 23, 2002 11:43 PM
gorockrx
15
Mar 6, 2002 10:11 PM
rotorhead46
Jan 7, 2002 10:30 AM
