Ground which boost sensor wire?
Old Sep 8, 2001 | 01:48 PM
TonyTurboII's Avatar
Glock Lover
I read grounding one of them helps with the 3700 problem, but which wire?
Old Sep 8, 2001 | 07:13 PM
fc3s.org's Avatar
OG
I don't think it was the boost sensor wire that is supposed to be grounded. I know that regrounding the standard ECU grounds will help if not totally get rid of the 3700-3800rpm studder of when the secondaries come online. Check my webpage for the wiring diagram in the FSM. It will show you there which wires are grounds.
streetlegal?
Mar 17, 2022 02:46 PM
Snoopy FD
Dec 8, 2015 01:45 PM
MoTeC
Sep 10, 2015 07:58 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
