Haltech Wiring O2 sensor help.
Old Jun 19, 2003 | 03:13 AM
fcturbo2's Avatar
Hey all.. i just bought a 4 wire Bosch O2 sensor from Autozone for my E6K that never came with the sensor when i someone sold it to me. How do i plug the sensor to the E6K harness??.. can i just use some butt connector and be done with it??..thanx in advance!
Old Jun 20, 2003 | 01:08 AM
fcturbo2's Avatar
bump
Old Jun 22, 2003 | 04:12 AM
fcturbo2's Avatar
bump.
Old Jun 22, 2003 | 01:44 PM
TYSON's Avatar
WTF is wrong with it now?
E6K Diagram
The 02 Sensor should have came with instructions showing which lead does what. Have a look at the E6K diagram here.
Your 4 wire has 2 ground wires, they can be grounded together as the E6K diagram assumes a 3 wire, which has the common ground built into the sensor.
Old Jun 29, 2003 | 05:00 AM
usually the wires that are the same color are your heater wires and can be hooked up in any direction. the other two will be constant +12v and the other will be signal to your ecu.
rgordon1979
40
Mar 15, 2022 12:04 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
acha3
Sep 6, 2015 08:14 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
