Autometer Boost Gauge
Old Jun 16, 2003 | 04:12 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
I would like to make a cosmetic change to the needle to make it match the stock gauges. Is there any way to open it up without breaking it?
Autometer 2401
Old Jun 17, 2003 | 04:52 AM
Juster's Avatar
i have the same one. i dont think you can but if anyone has please share with us
Old Jun 17, 2003 | 08:44 AM
HDP's Avatar
HDP
bump ^
Old Jun 18, 2003 | 01:53 PM
HDP's Avatar
HDP
Anyone?
Old Jun 18, 2003 | 04:37 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
You should be able to do it. I think the ring pops off... But I'm not sure. I was going to remove the faces and needles and put them in the stock locations in my FD, but never got around to really trying to tear them apart..
Old Jun 19, 2003 | 07:35 AM
HDP's Avatar
HDP
I inspected mine yesterday and the ring seems to be pressed/crimped on. Not sure if it can be opened that way.
Old Jun 19, 2003 | 12:07 PM
TwinTurbo93's Avatar
0-rotor-0-turbo-0-fd
I dont think you can oppen it from the ring, ring is crimped but I think you can take the whole cup with ring and glass out from back of the gauge there should be a nut in the midle where the fitting for hose is, you take that nut out and the cup should com right of and than you'll get its guts out.
Try that it may work, is been a pretty long while I haven't open one, I might be wrong though.
Old Jun 19, 2003 | 01:08 PM
maxpesce's Avatar
Ex fd *****
I don't think it can be done w/o destroying the Bezel - on the AutoMeter gauges the gauge mechanism is attached to the back of the housing and the glass faces are locked to the front of the housing by crimping the bezel. you can remove the mechanism (including the face & pointer) by cutting the bezel off the housing, However you have to destroy either the bezel or the housing to do so.
I am currently working on a custom instalation of some AutoMeter gauges in the inst. panel of my fd and so am very familiar w/ the construction of the gauges.
rgordon1979
40
Mar 15, 2022 12:04 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
gabescanlon
Sep 5, 2015 12:09 AM
