Fuel pickup problem with Bosch pump
Old Sep 7, 2001 | 01:58 PM
newRX7fan's Avatar
I recently installed the Bosch fuel pump. Now I'm having very annoying problems with getting fuel starvation during staight line acceleration. With the stock pump I never had this problem, even when the fuel gauge was on "E". Now I need to keep at least 1/2 a tank in there to prevent it. With a half tank or more there are no problems.
I eyeballed the position of the new pump to make the bottom of it at the same position as the stock one- its very close. Of course the new one doesn't have that white sock on it- is that just for straining the fuel (nothing to do with fuel pickup)?
I don't see why the fuel pickup would be so much different now. Has anyone else had this problem?
Thanks
Old Sep 8, 2001 | 12:24 AM
Marshall's Avatar
I have the EXACT same problem with my Bosche. Let me know if you find anything.
Old Sep 8, 2001 | 10:40 AM
alaskan7's Avatar
the bottom of the pump should be resting on the bottom of the tank, and did you do this: http://www.efini.net/images/fuel/pumpnut.JPG to the bottom of the pump so it could draw in fuel?
http://www.efini.net/fuel.htm
Old Sep 8, 2001 | 10:45 AM
Marshall's Avatar
Yes I ground a castlenut shape and I measured the installed height. It is resting perfectly on the bottom of the tank.
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
