Odd Question about Pedal-Pumping Starts
Old Jun 14, 2003 | 01:05 AM
vipernicus42's Avatar
Rotoholic Moderookie
Hey All,
So I'm reading through the forum today, and the oddest memory pops up.
As it seems to me, when the car was "running" many moons ago, sometimes mum would have to madly pump the pedal while turning it over to get it to start... So it'd turn and turn, almost catch, turn turn... Mum would pray (as is usual for her) I would coax the car with "come on little car... come on" ... and it'd start.
What could this be a sign of? Perhaps something related to my high-rev, start-only-on-choke problem? Or maybe just a sign of the old carb gumming up and going south? Or should I look into maybe fuel line system problems?
Jon
Old Jun 14, 2003 | 01:22 AM
Jeff20B's Avatar
Lapping = Fapping
Slow starter maybe.
Old Jun 14, 2003 | 01:28 AM
ioTus's Avatar
'84 5-letter
Slow starter, or battery draining down causing the starter to move slowly.
When i pump the pedal (even on my SE), i never floor it all the way, unless its almost catching. I finesse it right in the middle, to lower half of the range, i dont know, having a stuck injector just taught me that its way too easy to flood if you floor it. Same went with my last car (12a)..
For those who think pumping gas doesnt help on EFI, had you driven my car you would have been proved wrong.
Old Jun 14, 2003 | 01:35 AM
Well... The starter's been replaced, and the battery too So let's hope that was just the problem.
Could it have been a fuel delivery problem? Clogged fuel filter perhaps? Becasue the starter didn't seem to *sound* slower.... but my memory of this is really... foggy
Jon
Old Jun 14, 2003 | 01:44 AM
ioTus's Avatar
'84 5-letter
OK, well hard starting could be TONS of things, really:
1) Fuel delivery
2) Spark plugs
3) Spark Wires
4) Distributor cap and rotor
5) Spark plug wires
6) Ignitors
7) Your car's mood
8) Atmosphere (humidity, altitutde, your car's mood)
9) Your car's mood,
and well, it also really depends on how your car is feeling that day.
~Geoff
Old Jun 14, 2003 | 12:21 PM
Geez... now my car is starting to sound like my computer!
Jon
Old Jun 14, 2003 | 12:36 PM
Manntis's Avatar
add to cart
wierd. I barely touch the throttle on startup in my SE, and my old GLS would start with just the choke
Old Jun 14, 2003 | 01:26 PM
ioTus's Avatar
'84 5-letter
When the car was running like it was supposed to, i wouldnt have to touch the clutch or the gas.
But sometimes when the stuck injector was working its wonders, it would do exactly as described in the top post. Then, i would have to coax it over with gas, sometimes it worked, sometiems it didnt.
Old Jun 14, 2003 | 01:56 PM
Ah, but you see, mine's a GS, so stuck injectors are about as common problem to me as replacing the head gasket and having to get my cam shaft replaced
Jon
Old Jun 15, 2003 | 03:49 AM
jimmyrose99's Avatar
i really dont understand all this much, im completely new to rx7's and all yous talk about starting with choke and what not but all i do is hop in mine turn the key and it starts straight away every time ¿?
Old Jun 15, 2003 | 03:53 AM
ioTus's Avatar
'84 5-letter
Vipernicus, this was the case w/ my 85 gs, 12a carb, as well. ONly not as bad as teh gsl-se.
I was just trying to relate it to both worlds....
dam its late dont listen to me i make no sense.
alphawolff
Nov 17, 2015 05:57 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
befarrer
Aug 14, 2015 04:18 PM
