89 intake manifold
Old Jun 11, 2003 | 10:29 PM
Bruce's Avatar
Question 89 intake manifold
I have a 89 intake manifold I purchased off of a mechanic, what can I strip off of it to use for the my 88 intake manifold. ( I would have liked to do the swap but I don't have the resources)
Old Jun 11, 2003 | 11:45 PM
13bpower's Avatar
s4 for life
Its use the whole thing or nothing from my limited knowledge on the subject. What do you have in mind for swaping? There is nothing I can think of that would be even close to compatable.
Old Jun 11, 2003 | 11:53 PM
Icemark's Avatar
You will need to swap the entire 89 intake onto your 88. That includes the Upper, lower and dynamic chamber.
You will also need to grind a little on your 88 engine to make it fit. If you use the search function both here and in the achive, you should be able to find a complete write up of the swap.
Mind you, you will only gain about 10HP only at the upper rev range for the swap.
rgordon1979
40
Mar 15, 2022 12:04 PM
armans
Sep 6, 2015 09:02 PM
