Gage Cluster
Old Jun 11, 2003 | 06:49 PM
Guage Cluster
The lights for my guages went out. I pull the unit, and all the bulbs are good. I think there is a short between the fuse block(right name for it?) and the socket it hooks onto, and i am not sure i want to dig through the harness to find the short. I am think of just by passing the harness all together, just to get it working for now. anyone have any input on this? Also does any one know of a good place to look up a wiring diagram. Its a 88 10 AE.
Old Jun 11, 2003 | 06:57 PM
Makenzie71's Avatar
...94% correct.
number on...it's spelled "guage" not "gage"
number two...do your running lights go out as well?
Old Jun 11, 2003 | 07:03 PM
My headlights come on, so i don't think its the relay. But i could be wrong. They worked after i bought the car, but then it came home and sat in the driveway for a while, i have been working on it, but none of the interior wiring type stuff. The past owners of this car have cut wires where ever they see fit to get power for things. Anyways, any other ideas?
Old Jun 11, 2003 | 07:06 PM
Psychoblue23's Avatar
Is it easy to change the bulbs? I have never pulled the " gauge" before. And I dont really liek the orange. Also one bulb is out. ANy body know where I can get new ones?
- James
Old Jun 11, 2003 | 07:09 PM
Makenzie71's Avatar
...94% correct.
not headlights...running lights...we need to know if your running lights come on...it may be in the switch, which is notorious for failure.
Other wise just check over all the places where they've cut to splice in power supplies.
its easy to pull it out, i had a hard time getting it back in, i have large arms for hooking everything back up was a little bit of a problem.
Old Jun 11, 2003 | 07:10 PM
okay, sorry to be stupid, but when you say running lights which ones do you mean, the position between nonething, and the headlights coming on and up? Mean the orange lights in the front? Cause i would have called those parking lights, but maybe thats just me
Old Jun 11, 2003 | 08:44 PM
any idea what i might be able to try, i have tried following wires, and i am somewhat lost, any one have any ideas, ..... i need help
Old Jun 11, 2003 | 08:53 PM
Makenzie71's Avatar
...94% correct.
runnin lights are: parking lights, side marker lights, and tail lights
Look at the switch and tell us if any of the pins or anything are burnt.
Old Jun 11, 2003 | 09:17 PM
RXciting's Avatar
GrapefruitRacing?
LOL number one.... it's spelled one! :P
Old Jun 11, 2003 | 09:21 PM
Makenzie71's Avatar
...94% correct.
hahahahaha....that's great...I love when **** like that happens...
Old Jun 11, 2003 | 09:29 PM
the parking lights and such come on, i am about to check the switch, is there any way to bypass the relay, so that the lights are always on?
Old Jun 11, 2003 | 09:34 PM
nothing is bent or out of place it looks.
Old Jun 11, 2003 | 09:54 PM
Makenzie71's Avatar
...94% correct.
you can't really bypass the switch without hard wiring them with another switch...been down that road.
Old Jun 11, 2003 | 10:07 PM
all i want is for the lights to come on, when you went down that road did you get it to work right? If so, could you explain to me what to wire where?
Old Jun 11, 2003 | 10:11 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
#1: In the USA It's spelt Gauge. Not guage. It's spelt gage in canada, according to GM. (look at the inside of any Canadian cavalier, and gauges is spelt gages. wtf, I dunno why.)
#2: There is no number two. Make sure when you correct people's spelling, you spell it right yourself.
Old Jun 12, 2003 | 02:43 PM
bump
Old Jun 12, 2003 | 03:41 PM
Rotary Racer's Avatar
Zoom Zoom Boooom
Ok I am going to jump in here and see if I can help.
When you turn on your lights do the rest of your interior lights/illuminations (IE radio lights, HVAC lights, etc) come on? If none of your lights come on then you probably have a bad switch. Mazda over engineered these switches and they are prone to failure in all sorts of weird ways. I believe I have an extra working one laying around if that is your problem I will just send it to ya.
- Dana "This is not an English class"
Old Jun 15, 2003 | 01:39 PM
you brought up a good point rotary racer, and none of my hvac lights come on, and unless the stero is wired bad, it doesn't come on either, and it use to.
