any way of knowing
Old Jun 11, 2003 | 05:58 PM
turbo II addict's Avatar
any way of knowing
is there any way of knowing if your pulsation damner is bad or is going
Old Jun 11, 2003 | 06:08 PM
Icemark's Avatar
yeah it leaks, or on the S4 versions the screw comes out when you pop the cover off.
Old Jun 11, 2003 | 06:58 PM
NZConvertible's Avatar
I'm a boost creep...
Read my post here.
Old Jun 11, 2003 | 07:12 PM
ViperKillerWannabe's Avatar
Resident Moonwalker
I heard that S5s don't have this problem, is that true?
Old Jun 11, 2003 | 07:15 PM
sonic7's Avatar
less likely in s5 but still a possibitlty as there are still engine fires caused by them.... definately check the screw on s4 cars, you can see it if you pop the plastic cap off. MINE HAD FALLEN OUT!!!!
Icemark's Avatar
S5s don't have the screw, but still have the problem of getting old and leaking.
The draw back with the S5 design is if the PD leaks, you have to replace the whole fuel rail, not just the PD as you can on a S4.
Old Jun 11, 2003 | 07:19 PM
Resident Moonwalker
oh :goes and checks his pulsation dampener:
Th0m4s
Feb 26, 2019 02:04 AM
Jun 26, 2016 10:21 AM
Engine stand ready
Aug 14, 2015 10:26 PM
