Emissions Removal Help
Old Sep 6, 2001 | 08:39 PM
kliftin's Avatar
HI. I TOOK OUT MY AIR PUMP ON MY 89. ANYTHING ELSE I NEED TO DO. IM GOING TO TAKE OUT MY 6 PORT SLEEVES LATER AND NEEDED TO LEARN HOW TO TAKE EM OUT. THE MANIFOLD IS EXPOSED RIGHT NOW BUT DONT WANT TO BOLT IT OFF.
ALSO, IM TAKING OUT THE POWER STEERING AND DONT KNOW WHAT TO DO WITH THE THREE LINES CONNECTED TO IT. IS THIER FLUID COMING OUT. IS THIER MY OIL PUMP CONNECTED TO IT?
ALSO I WANT TO TAKE OUT ALL THOSE SELENOIDS,RELAYS,REGULATOR THINGS. THEY HAVE COLORFUL CONNECTORS ATTACHED BY METAL TUBES. DO TAKING OUT THESE TUBES MAKE THE CAR NOT RUN GOOD. MY INTAKES OFF AND NOTICED IT WOULD BE ALOT CLEANER WITHOUT THOSE METAL TUBES AND HOSES. IT ALSO ATACHES TO THE ACV THAT I WANT TO TAKE OUT.
IF SOMEONE HAS DONE THIS LIKE MAZDASPEED7, PLEASE TELL ME. IM IN THE CAR NOW BECAUSE OF A OIL LINE THAT ALMOST BROKE OFF AND DONT WANT TO DO THIS WHOLE PROCEDURE AGAIN.
Old Sep 6, 2001 | 08:52 PM
RX-7 GT's Avatar
HyperREV.com
i know you have to remove your cats, cause it will ruin em.
Old Sep 6, 2001 | 09:20 PM
kliftin's Avatar
YES
I HAVE MANIFOLD AND STREIGHT PIPE.
Old Sep 6, 2001 | 10:31 PM
kliftin's Avatar
bam
bam
Old Sep 6, 2001 | 11:16 PM
kliftin's Avatar
BOOOOOOM
WHITE 89 GXL
Old Feb 1, 2004 | 10:16 AM
Peruvianrx7's Avatar
please i want to know to, is there a write up on how to take emmisions out on an s5 rx7?
Old Feb 1, 2004 | 10:35 AM
Molotovman's Avatar
Ban Peak
your car working again peruv?
Old Feb 1, 2004 | 11:02 AM
Well first hit the caps lock button . Anyway yea take out the cats cause they will be ruined soon enough anyway. Here is an awesome site about removing **** that you don't need: http://www.rotaryresurrection.com/emissionsrem.html
Good luck!
Old Feb 1, 2004 | 11:18 AM
nope. molotovman my car is still dead as my grandma. Im just asking for a friend of mine...but thanx for caring dawg
edit:
Rotary ressurection ( kevin) doesnt go into detail on the s5 removal write up.
Old Feb 1, 2004 | 11:31 AM
andrew lohaus's Avatar
coming soon: lumbar pump aux port and vdi activation writeup! WOOOOOHOOOOOOO. it'll anser your questions and is about as simple as you can make electronic aux ports. i gota get my pics developed...........
Old Feb 1, 2004 | 08:16 PM
NZConvertible's Avatar
I'm a boost creep...
Between the info in the archives and the schematics in the FSM, there's more than enough info available to successfully remove the emission controls. It just requires a little research, and (gasp!) some work on your part to work it all out.
ZacMan
Sep 19, 2015 09:20 PM
Steelwheelz
Sep 15, 2015 03:22 PM
