How much fluid does a 87 T2 rear diff take?
Old Jun 10, 2003 | 01:47 PM
Dougster's Avatar
Hey guys, I am going to pick up my new 87 T2 here in a few hours and one of the first things I am changing is the rear diff fluid with Mobil One synthetic Tranny oil, Does anyone know off hand how much it takes? More then 1 quart? Thanks much for the imput!
Old Jun 10, 2003 | 01:50 PM
BlackRx7's Avatar
Daily Domestic Killer
1.3 qts
Old Jun 10, 2003 | 02:00 PM
Dougster's Avatar
Cool, thanks much!
Old Jun 10, 2003 | 02:38 PM
pmr2000's Avatar
It's actually 1.4 quarts (1.3 liters), make sure you have extra because its tough to fill. I would just fill until it starts to come out of the fill plug, then let it level out.
Old Jun 10, 2003 | 02:42 PM
Dougster's Avatar
OK, thanks again, Any idea what size bolt is used?
Old Jun 10, 2003 | 03:01 PM
pmr2000's Avatar
Just suffered through this myself for trans and diff but forgot which was which. Had to buy a 23 and 24 mm socket which are half inch drives. Get both you'll be all set, trans fill is 16mm.
Old Jun 10, 2003 | 03:04 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I don't remember a 24.... but a 23 and I think either a 19 or 21 for the diff. undo the top one first!!!!
Old Jun 10, 2003 | 03:33 PM
Rob500's Avatar
Mine are square pipe plugs. A hex socket will round them off.
Rob
Old Jun 10, 2003 | 03:51 PM
Dougster's Avatar
HMMM? I will have to crawl underneath there & check it out. Yes, I have read (and it makes great sense) to open the top first, to make sure you can replace the fluid with new first before draining out the old!
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
